AVS › AVS Forum › Video Components › Home Theater Computers › Vista MCE How many digital tuners?
post #1 of 7
I've read a few threads and I would like to have 3 digital tuners(clear QAM) and 1 analog working under Vista Media Center, is it possible? I'm currently using the HDHR and it has no problem with the dual tuners. If I'm limited to two digital in MCE, I assume I could use a standalone tuner such as OnAir Creator/GT and use it's own software to record analog and digital with it in addition to MCE recording with the HDHR device.
Are there any plugins that will play ts stream files in MCE that will allow fast forward/skip and/or rewind functions using the remote control? I've got MCE playing ts files, but I have no real control over them other than pause and stop.
post #2 of 7
Any thoughts on the subject?
post #3 of 7
Without hacking the registry, mce will support 2 analog tuners and 2 digital tuners. if you make some easy changes to the registry, you can use any number of analog or digital tuners. For example, I have 4 analog tuners and 2 digital tuners.
There used to be a little utility someone wrote that allowed you to manage extra tuners, but I could never get it to work.
http://thegreenbutton.com/forums/thread/46023.aspx
I can't help you with the ts streams question. Sorry.
post #4 of 7
Thanks, I'll give it a go, unfortunately my motherboard is out for replacement, but if I can get the tuners to all work in MCE, then the ts streams problem won't be an issue, since I'll be recording everything in dvrms anyway.
post #5 of 7
no prob.
btw, I use the "n tuners in mce method 1" from that post. I found it was the easiest to do.
post #6 of 7
When you guys use analog as wel as digital tuners in your htpc, how do you choose wich one is used for a specific recording?
post #7 of 7
it depends on which channel you choose to record something on. the analog channels are numbered 1 - 99 and the digital ones start at 1000.
