AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Olevia 247TFHD Owners Thread
post #1 of 1298
I started a thread asking if there were any owners of this TV. It turned into a discussion of the Circuit City deal, and has some great info.
I decided to start a new owners thread. Here you can post
- Tips for configuring your Olevia 247TFHD
- Troubleshooting your Olevia 247TFHD
- Post pictures of you Olevia 247TFHD Setup
- Anything else regarding the Olevia 247TFHD
Post away!
Here is the original thread I created
http://www.avsforum.com/avs-vb/showthread.php?t=942633
COMPANY INFO
Support Phone and Mail-Back Address:
Technical Support, Customer Support and Rebate Status:
1.866.9OLEVIA (965.3842)
Olevia Returns
LCD Operations
20480 E. Business Parkway
City of Industry, CA 91789
Tel: 1.909.859.8400
Fax: 1.909.859.8401
Headquarters
1600 N. Desert Drive
Tempe, AZ 85281
Support:
http://www.olevia.com/en-us/Support.aspx
Olevia 247TFHD on website
http://www.olevia.com/en-us/Products...HDLCDHDTV.aspx
SETUP/CONFIGURATION:
- Pronto Codes
http://www.avsforum.com/avs-vb/showt...4#post12319694
- "Backdoor" firmware site, thanks swampass2
http://64.168.125.230/support/Syntax/Television/
- JP1 remote source, thanks swampass2
http://www.hifi-remote.com/forums/
- Harmony remotes support Olevia according to Sonar5
http://www.avsforum.com/avs-vb/showt...0#post12335780
ISSUES:
vidiot1985 posted
- "Is anyone else seeing 4:3 analog content being shown in a slightly squashed 1.5 ratio rather than 1.33 in Aspect mode and even in 1:1 mode?"
4:3 digital content seems correct though."
- several people reported that the Digital output, both coaxial and optical, do not output a 5.1 signal. This may be fixed with Firmware in the future. It is recommended that you run audio from the source (DVD, HD-DVD, Blurray, Xbox 360) directly to your receiver if you want 5.1 sound.
- several people have reported some backlight bleed. This can be reduced by changing the "Lighting" setting on the remote/menu to "Dark Room".
More info here on backlight bleed
http://www.avsforum.com/avs-vb/showt...7#post12324847
INSTALLATION TIPS:
How to remove the stand and speakers, thanks EricRP
http://www.avsforum.com/avs-vb/showt...8#post12326838
Several people have recommended Monoprice for cables
http://www.monoprice.com/home/index.asp
Cable Tips
http://www.crutchfield.com/learningc...me/cables.html
dcv_2002 posted a wall plate
http://www.mycablemart.com/store/car...t_detail&p=786
PICTURES:
Credenza by spydermonkey311
IMAGE 1 - Lights Off
IMAGE 2 - Lights On
Several people have asked me where I purchased my Credenza/TV Console. Here is the link for it @ Sams Club
http://www.samsclub.com/shopping/nav...1-01-07_HolCat
Wallmount by EricRP
http://www.avsforum.com/avs-vb/showt...8#post12333518
TV Stand by Draco098
http://www.avsforum.com/avs-vb/showt...0#post12336660
Credenza by wapow
http://www.avsforum.com/avs-vb/showt...1#post12337231
FAQ
Q: How does the Idea menu work?
A: It lets you choose one of four settings: Off, White Peak Limiter, Black Level Enhancer, Contrast Enhance. You can't combine them.
Q: Which should I use, the Native or the 6500K color temperature?
A: Most people here have found Native to produce better looking results, despite Olevia's recommendation to use 6500K.
Q: What resolution does the VGA connection work at? Is it bogus like most TVs, which limit you to some lower resolution?
A: It works at the full 1920x1080 @ 60Hz over the VGA connection.
Q: Does this TV have Picture-in-Picture? Some vendors don't list it as a feature.
A: Yes, it has PiP and Split Screen. The PiP lets you pick which corner to use for PiP, as well as a limited number of sizes for the PiP display, which also changes aspect ratios as needed. The combination of sources is slightly limited, e.g. VGA can PiP with the built-in tuner, HDMI, S-Video and Composite, but not with Component.
MISCELLANEOUS:
Warranty Card for Olevia
http://www.avsforum.com/avs-vb/showt...4#post12321544
Extended Warranty by RepairMaster
http://www.avsforum.com/avs-vb/showt...8#post12326918
Extended Warranty from BJs
http://www.avsforum.com/avs-vb/showt...3#post12328183
Somewhat discouraging article, please chime in your opinion on what this blogger says, thanks argeleri for the link
http://hdguru.com/?p=107
"Vizio leads the Low End", thanks Frankenstein for the link
http://www.fool.com/investing/value/...e-low-end.aspx
"Syntax-Brillian is a Hornet's Nest" UPDATE to the article above thanks eegorr
http://www.fool.com/investing/value/...nets-nest.aspx
post #2 of 1298
OK, just in case my post from the other thread gets lost....
1. Wall mount suggestion? (Was going to get one from monoprice)
2. Going to mount this on a wall, would like to run cable in-wall (yes I know I have to make holes). What would you run up to the mounting location: (2 HDMI ports, 1 component, 1 VGA, 1 power)
What about coax cable, coax audio? Also, does electrical wiring cause interference with any of the above cabling?
post #3 of 1298
post #4 of 1298
Tagging along on this thread too! I'm looking forward to getting my DVI-to-HDMI adapter for my MVIX movie player. It will send 1080p signals via the DVI port. Right now I'm watching movies via a 480i 60Hz component set of cables, and while it looks nice, I'm curious to see how it will look via the new cable.
post #5 of 1298
Electrical wiring can cause interference with any of those wires. Its best to install the electrical wire away from the audio/video wires.
Because they can introduce interference into the signal, try to keep power cords away from signal cords. If this isn't possible, at least try to minimize contact between the two.
More tips here
post #6 of 1298
If the content on your MVIX supports 720p or 1080p, then it should definilty look better. HD looks stunning on this TV. Is it just me, or do the black levels look alot better on HD content than SD ?
Regarding your MVIX, what kind of cable are you using for audio? I plan on trying my MacBook Pro which has a DVI output. The only audio output is a standard 3.5" plug.
post #7 of 1298
More tips here
So basically run the A/V wiring one way and the power the other. The A/V stuff on this TV is on the left side is the plug on the right side?
post #8 of 1298
If you could run one setup of cables on one side of the stud and the electrical on the other, thats what I would do.
post #9 of 1298
I can test this out today at lunch. What exactly should I be looking for? Is it squashed from top to bottom or side to side? Can you change the Aspect on your remote to correct this?
post #10 of 1298
Right now I'm just using RCA cables to the TV for audio. We moved just over a month ago and our current living room isn't, let's say, Home Theater "friendly" so I'm going to finish the basement and put the surround system and 47" TV down there when I get to it. For now the TV will have to suffice for audio.
post #11 of 1298
I think that is what I am going to do. (This is going above a fireplace). So on one side of the fireplace I will run up electrical to a new outlet plug. On the other side of the fireplace I will run up the wires to the TV. I was going to install HDMI wall plates etc, etc. but it seems that there is too much stuff that you could possible hookup to this TV or any future TV, so I was thinking of using something like this:
Putting one up by the TV and another down near the floor where the equiment goes. Now looking at the cables how big of a hole do you need to get these cable heads through. Especially HDMI. Also is the higher the AWG the better?
So basically since I only want to punch holes in the wall once. I should just run
2 HDMI
1 VGA
1 Component
Maybe: Digital Coax, Tosc Optical, ?USB?, ?DVI?, ?Regular Cable?
post #12 of 1298
It will be squashed slightly top to bottom. Changing the aspect modes doesn't really fix it. The only way to get 4:3 SD analog to look right that I've found is:
- Split Screen, Aspect mode
- Full Screen, Zoom1 mode (but then you lose content at the edges, perhaps just vertically, unless it's letterboxed)
The "technical" method would be to tune to a 4:3 analog channel in Aspect mode with a full screen program on, then take a tape measure to the visible portion and divide the width by the height. It should be 1:33, but will end up being 1.5. I think even in 1:1 mode, the aspect ratio will still be wrong.
The visual method is to tune to a 4:3 analog channel that has a 4:3 digital equivalent and then do a "channel return" between them. You'll see the picture from the same program getting wider on the analog channel, then normal on the digital channel.
Or just tune to a 4:3 analog channel in Aspect mode and look at how narrow the black bars on the side are.
While I noticed this problem while watching 4:3 full screen cartoons and stuff like that, it really showed up while watching a letterboxed movie on TCM--it was "A Patch of Blue" http://www.imdb.com/title/tt0059573/. When watching it, I knew Shelley Winters wasn't as short and squat as she appeared on the screen. I switched to Zoom1, it filled up the screen nicely and people looked normal.
post #13 of 1298
2 HDMI
1 VGA
1 Component
Wire guage is like shotguns the smaller the number the bigger the wire, the bigger the wire the better the cable...
If getting to the back of the set would require removing it from the wall, I think I would run a wire for every connection the tv has, and tape off and not connect any not used wire on the lower end. If you, are a belt and suspenders type, put in a spare HDMI and Component cable just in case...
post #14 of 1298
Has anyone figured out how to get Digital 5.1 from the coax or optical digital audio outputs? I am trying to get ATSC tuner feeds that are transmitting 5.1 signals and my receiver keeps showing PCM stereo. This is annoying since I never use the internal speakers. I can get digital 5.1 feed from my $399 32" no-name Fry's HDTV in my bedroom.
I hope this can be fixed since I love the video display on this unit. The MTK video processing of SD sources is one of the best I have seen in 47" size HDTV. With true HD sources, most HDTV are pretty close. But for a long while we will still have SD sources transmitted over digital channels.
post #15 of 1298
I know that these are relatively new TV's, but has anyone attempted to update the firmware, or is that not necessary?
post #16 of 1298
There is no firmware update available as of last night.
But many of the problems I and others have noted in the other 247 thread are things I think should be fixable with firmware.
post #17 of 1298
Pearl Jam is on the the MHD channel right now....stunning.
post #18 of 1298
Anyone know how good Olevia is with releasing new firmware for their Tvs?
post #19 of 1298
Thank you.
post #20 of 1298
I'm curious what temp setting most people use? 6500 or native? I think native looks better, but even in the manual it says to choose 6500... why?
post #21 of 1298
At the very least, Olevia is outwardly supportive of fixing issues via firmware updates. Their manual specifically mentions updates, pointing to the web page for it, and they even have a "FutureProof(TM) Your TV" link that highlights the firmware upgradeability as a trademarked feature.
Let's hope it's not just empty hype. Since they require a serial# to get to their firmware downloads, it's hard to see how they've been with older models.
post #22 of 1298
Has anyone contacted Olevia regarding the Extended Warranty that they offer? The 247TFHD is not listed on the brochure. I emailed them about this, I will post their response here.
post #23 of 1298
Slightly off topic, but hopefully not too much. I bought mine at BJs for $999 and opted out of the extended warranty. Was that a bad move and should I get an extended?
post #24 of 1298
New owner here. So far I'm very impressed with the 247, regardless of the brand.
For anyone who has calibrated their set, would you please share the settings?
I'm curious to play around and see if i can get even better results from it.
post #25 of 1298
I was wondering the same thing with my purchase from Circuit City. CCs extended warranty is around $250 for 3 years. Olevia has their own Extended Warranty you can buy, but this model is not listed (see my previous post).
How much does BJs sell the warranty for? You normally have 30 days to buy the warranty.
post #26 of 1298
Most credit cards these days already double the warranty for free (I think usually up to an additional year or two??). So I think I'd be OK with a two year labor and on-site warranty.
If you do get an extended warranty, check to see if your credit card's extended warranty adds an additional length onto it, or if they end up running parallel and being kinda worthless (unless one gives you a hassle but the other one covers you on a claim).
post #27 of 1298
Here are the codes for direct input in pronto format. There is a tutorial on the web explaining how to program the harmony RC with pronto codes, but since this is my first post I cannot put links.
No more pressing source button to get somewhere.
composite 1
0000 006C 0022 0002 0158 00AD 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0042 0015 0016 0015 0016 0015 0042 0015 0042 0015 0042 0015 0016 0015 0042 0015 0016 0015 0016 0015 0042 0015 0016 0015 0016 0015 0016 0015 0042 0015 0016 0015 0041 0015 0042 0015 0016 0015 0042 0015 0042 0015 0041 0015 0016 0015 0041 0015 064D 0158 0057 0015 0E5A
composite 2
0000 006C 0022 0002 0158 00AC 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0042 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0042 0015 0041 0015 0016 0015 0041 0015 064D 0158 0057 0015 0E58
svideo 1
0000 006C 0022 0002 0159 00AD 0015 0017 0015 0017 0015 0042 0015 0017 0015 0016 0015 0017 0015 0017 0015 0017 0015 0042 0015 0017 0015 0017 0015 0042 0015 0042 0015 0042 0015 0017 0015 0042 0015 0017 0015 0042 0015 0042 0015 0016 0015 0017 0015 0017 0015 0042 0015 0017 0015 0042 0015 0017 0015 0017 0015 0042 0015 0042 0015 0042 0015 0017 0015 0042 0015 0650 0159 0057 0015 0E60
svideo 2
0000 006C 0022 0002 0158 00AD 0015 0016 0015 0017 0015 0042 0015 0016 0015 0016 0015 0016 0015 0017 0015 0016 0015 0042 0015 0016 0015 0016 0015 0042 0015 0042 0015 0042 0015 0016 0015 0042 0015 0042 0015 0042 0015 0042 0015 0016 0015 0016 0015 0016 0015 0042 0015 0017 0015 0016 0015 0016 0015 0016 0015 0042 0015 0042 0015 0042 0015 0017 0015 0042 0015 064E 0158 0057 0015 0E5B
component 1
0000 006C 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0646 0157 0057 0015 0E4A
component 2
0000 006C 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0647 0157 0057 0015 0E4A
hdmi1
0000 006C 0022 0002 0158 00AC 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0042 0015 0016 0015 0016 0015 0042 0015 0041 0015 0042 0015 0016 0015 0041 0015 0042 0015 0042 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0042 0015 0016 0015 0042 0015 0041 0015 0016 0015 0042 0015 064D 0158 0057 0015 0E59
hdmi2
0000 006C 0022 0002 0158 00AC 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0042 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 064D 0158 0057 0015 0E58
post #28 of 1298
The extended warantee card in the box says the extended warrantee for the 247T is $350. 30% of what you pay for the set seems a little steep. I will probably just take my chances. Bought this TV for the den and have a 67" inch DLP in the home theater. So far I am pretty happy with this set but have only used it on the DirecTV HD satalite box.
post #29 of 1298
I checked my set. Analog stations via the NTSC tuner are about 1.5:1 and Digital stations via the QAM tuner are 1.33:1. This certainly seems to be a defect.
I thought those black side bars looked a little narrow.
Edit: I noticed one more thing. If the 4:3 digital content is 480i, the picture is also squashed. If the 4:3 digital content is 720p or 1080i, the aspect ratio is correct at 1.33:1. It seems it's a 480i issue, not an analog/digital issue.
-TurboWells
post #30 of 1298
Interesting. I dont see the model listed on my warranty card.
