Originally Posted by
auburnu008
Can someone
design a ported box for 2 of these?
A slot port would be great.
I am planning on building one of these for a friend and just bought
2 of the 4ohm versions. I will be using either a
270 or 300 watt plate amp to power them. Thanks!
If you ~{plan to use 2 drivers in one cabinet and power it with a single plate amp}~, you might consider calling back and getting the 2-ohm version. Then you can wire the two 2-ohm drivers in series for a 4-ohm load to your plate amp.
Other wise, using two 4-ohm drivers in one cabinet your stuck with either a 2-ohm load or 8-ohm load to the plate amp. 2-ohms not plate amp friendly and 8-ohm dropping your plate amps power output.
As far as a ported design for 2 drivers, just double up the cabinet volume of eD's design for one driver and use the same tuning, 20Hz..
Being that the EHQS 12" driver needs a somewhat large ported encloser ~{for just one driver}~, using a slot port is just going to make the encloser even bigger. Might be a better choice to go with a pair of 3 or 4" Precision ports or even flared PVC pipe, unless you don't mind the added encloser size when using a slot port to save a few dollars.
Being that
ashardin has already built a pair of
dual EHQS 12" driver enclosers you might ask what he went with for his encloser ft^³ size and also the tuning frequency he used.
If your going to purchase a plate amp for your dual driver EHQS DIY sub, you might consider the
PE-240. It's rum filter is a very nice fit if you choose to go with ~{
eD's internal volume x two and it's 20Hz tune}~. 120-watts per driver is about perfect for this with the rum filter helping out to protect the drivers below tuning..
The link to eD's 12" EHQS sub build with all it's necessary information is below. Just me, but I'd add at least one brace inside.
http://www.icixsound.com/vb/showthread.php?t=39744
Thank CarlsonCustoms for digging that thread build up..
Later
Geoff ¥
