AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › A3 vs A30 - Any difference?
post #1 of 4
Besides the A30 being 1080p, does the A30 do anything different then the A3? Upconversion better for SD DVD?
post #2 of 4
With the exception of 1080p60 and 1080p24 I believe these units are the same.
post #3 of 4
The A30 also adds:
"CE-Link for streamlined control of compatible Toshiba TVs via HDMI"
post #4 of 4
The A30 and A35 use the ABT1018 chip from Anchor Bay Technologies which will give you better SD DVD upconversion than the A3 can do.
Edit: more info:
http://www.avsforum.com/avs-vb/showt...php?p=11994743
  Back to Forum: HD DVD Players
