So, I can get it to look approximately right, but aspect ratio is not quite right on my TV.
If I'm watching standard analog feed with the TV set to "TV", the picture shows up only on the middle, as it should. and it's exactly 1.33
If I'm watching a 720p feed through HDMI through DVD player, I have to set the TV to "full" as normal makes everything the aspect ratio about 1:1 and it makes the aspect ratio 1.40. "in full mode" the middle is not stretched, but strentching is added to sides.
If I put on Wide, there is cropping.
Is it just crappy aspect ratio control on my Mag 32" TV?
