I just got my replacement bulb today and I'm wondering what is the correct way to shut down the Sony Pearl? I've read that it's better to leave it on for 6+ hours at a time even if not using it, is this true?
Do I leave it on for hours a time before cutting the power? How could this work to cool it down, though? - The lamp would be running the entire time, hence keeping it hot.
Is there a way to shut off the lamp while leaving the fans run? Would this be the right way to do it? I could see doing this for six hours or so before cutting the power, as the fans would cool the bulb down. I had the Pearl on Power Save mode which did this, but a few hours later, I pressed the Power button on the remote, and it simply turned ON the projector.
Thank you.
Thank you.
