AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Can I use AE2000 in China with 240 Volts power?
post #1 of 3
Hi Guys,
I was wondering if I take this projector with me to china or other european countries and use it with an adaptor? as you know the power there is different than ours 120 volts. also what if I take the blue ray player, will it also play? thanks
sean
post #2 of 3
It says on the AE2000 manual that it can take 120-240 volts. It also says that the cable supplied with the AE2000 should only be used with 120V sockets, so if you are in a 240V country, the cord should be replaced.
post #3 of 3
Originally Posted by Jones_Rush View Post
...so if you are in a 240V country, the cord should be replaced.
Or, like we do in the 220V countries, get a good (110 to 240) plug adapter
