Originally Posted by
Wo0zy
Hi P.Viby,
We're always polite (honest)
Can you post the report from the Intel Graphics Tray? If you save it first, the resulting .txt will include the EDID information from your screen. If we can get this I'm sure we can come up with something for you.
Cheers,
Wo0zy.
Hey Wo0zy.
Here we go with the Graphics Tray info:
Intel(R) Graphics Media Accelerator Driver for Mobile Report
Report Date: 02/03/2008
Report Time[hr:mm:ss]: 18:45:12
Driver Version: 7.14.10.1350
Operating System: Windows Vista (TM) Home Premium* , (6.0.6000)
Default Language: Danish
DirectX* Version: 10.0
Physical Memory: 1013 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 251 MB
Graphics Memory in Use: 188 MB
Processor: x86 family 6 Model 15 Stepping 6
Processor Speed: 1667 MHZ
Vendor ID: 8086
Device ID: 27A2
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel(R) 945 Express Chipset Family
Video BIOS: 1358
Current Graphics Mode: 1184 x 666 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Digital Televisions: 1
* Digitalt tv *
Monitor Name: Standard PnP-skærm
Display Type: Digital
Gamma Value: 2,20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: Not Available
Vertical: Not Available
Monitor Supported Modes:
1280 x 720 (50 Hz)
1920 x 540 (50 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 ff ff ff ff ff ff 00 34 a9 37 a0 12 00 00 00
29 0f 01 03 80 00 00 78 0a da ff a3 58 4a a2 29
17 49 4b 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 01 1d 00 bc 52 d0 1e 20 b8 28
55 40 9a 26 53 00 00 1e 01 1d 80 d0 72 1c 16 20
10 2c 25 80 9a 26 53 00 00 9e 00 00 00 fc 00 50
41 4e 41 53 4f 4e 49 43 2d 54 56 20 00 00 00 fd
00 30 3d 0f 2d 08 00 0a 20 20 20 20 20 20 01 b2
02 03 1c 74 4c 93 94 12 84 85 03 16 07 11 06 15
01 23 09 07 01 66 03 0c 00 10 00 80 8c 0a d0 90
20 40 31 20 0c 40 55 00 9a 26 53 00 00 18 01 1d
00 72 51 d0 1e 20 6e 28 55 00 9a 26 53 00 00 1e
01 1d 80 18 71 1c 16 20 58 2c 25 00 9a 26 53 00
00 9e 8c 0a d0 8a 20 e0 2d 10 10 3e 96 00 9a 26
53 00 00 18 8c 0a d0 90 20 40 31 20 0c 40 55 00
33 26 43 00 00 18 00 00 00 00 00 00 00 00 00 ce
* SDVO Encoder Report *
** Encoder 1 **
Vendor ID: Chrontel
Device ID: 60
Device Revision: 6
Major Version: 1
Minor Version: 1
* Other names and brands are the property of their respective owners.
