Originally Posted by
Conspiracy*
I've always been semi-confused about how the box handles HD content. Doesnt it simply upscale EVERYTHING to whatever you tell it to? Like what an upscaling DVD player does with SD DVDs? If so, I dont understand how they can even call it HD. Doesnt the media limit HD capabilities? You cant get HD content on a dvd can you? If so, is the only drawback space? Isnt component cables limited in bandwidth and unable to pass 1080P? Aside from the possible hardware limitations...whats so special about this supposed 1080P? I've seen side by side 1080P and 720P on the same model sets playing the same movie and couldnt tell a difference. I know that "technically" there are more dots on the screen but does that necessarily mean its better? In the box's case, is there even really more dots or are they just created using the scaler in the box itself?
I know a lot of people get confused about that. I'll try to explain your wonderings as best as I can.
1) Doesn't it simply upscale EVERYTHING to whatever you tell it to?
Not as far as I can tell. From what others here said, if you're using HDMI all media and PSX/PS2 games will render in 1080p but the game's ability to render in 1080p is dependent upon the developer and will possibly render as 960x1080p and then the horizontal pixel doubled to 1920.
2) Like what an upscaling DVD player does with SD DVDs?
SD-DVDs because of the MPAA licensing threats and agreements only allow 1080i/p and 720p upscaling with HDMI using HDCP.
3)If so, I dont understand how they can even call it HD. Doesn't the media limit HD capabilities?
It isn't true-HD, it's upscaled HD. But depending on the output device or the TV, either the TV or outside scaling device might be better. The only way to know is to test yourself and see which you like better.
4) You cant get HD content on a dvd can you?
Yes you can, such as the Terminator 2 DVD which has a WMV format of the movie on a supplemental disc in 1080i but very few if any DVD players will play it, so about your only option is to use a computer. A DVD is just a way of storing information. You can store anything you want, but if you're talking about DVD video, then no, HD isn't part of the spec. DVD video is either 720x480p NTSC or 720x576p PAL. The DVD then has a pixel aspect ratio flag which says if it's either: 4:3, 16:9, 2.4:1, or 1.85:1, etc and the pixels are then expanded by the player. This was developed years ago for use on CRT. On a CRT vertical resolution is fixed timing, but horizontal isn't. Each new pixel horizontally can be drawn sooner or later, which will make the pixel drawn wider or narrower.
5) If so, is the only drawback space?
Yes. Dual layer has up to 8.5 gigabyte while single layer has only up to 4.7 gigabyte.
6) Isnt component cables limited in bandwidth and unable to pass 1080P?
NO! Component can do 1080p just fine. The "limitation" is because of DRM overlords such as the MPAA who limit component to a maximum of either 480p, 720p or 1080i, depending on what's being sent. Component can't use HDCP, HDMI can, so most of the time as long as HDCP is used, there's no 1080p "ban".
7)Aside from the possible hardware limitations...whats so special about this supposed 1080P? I've seen side by side 1080P and 720P on the same model sets playing the same movie and couldnt tell a difference.
There are tons of advantages to 1080p over 720p. A major advantage is if you sit 1.5 times the width of the tv or closer, 1080p pixels aren't as noticeable. If you can't tell the difference, you're either not close enough or not paying attention. The differences between 1080p and 720p can at times be subtle. It depends on the person.
8) I know that "technically" there are more dots on the screen but does that necessarily mean its better? In the box's case, is there even really more dots or are they just created using the scaler in the box itself?
It depends on the source. With Blu-ray and HD-DVD you're using all 1920x1080p pixels. With 1080i, on a fixed pixel device, a 1920x1080p display is the only way to get all 1920x1080 pixels from a 1080i signal. For any other resolution other than 1080i/p or 1080p/24, the pixels somewhere in the chain are being created and then displayed.
Hope that helps?
Johnsteph10
Let's drop the 360 bashing/discussion and back to PS3 please!
Yes, please do! That wasn't my intent. I was just explaining where I was coming from and what would I be gaining and losing by switching sides as far as 1080p support goes.
