Originally Posted by Bill Mitchell
Looking at the Y value measured for white (189.489 for ANSI white, 155.311 for IRE100 white), it appears that the ANSI Contrast pattern is based on computer/PAL RGB values of 255 and (probably) 0 for white and black, whereas the black then white full field on/off contrast patterns use 16 and 235 for black and white. Am I reading the data correctly and is this intentional?
(I would have compared this against the HCFR disk, but unfortunately that is a PAL disk, so even if it might be 0-255 in the PAL version, my second, multiregion player should remap the Y values to NTSC studio range, and I have other indications that it clips BTB and WTW.)
Bill
Bill
I think you are right, Bill. I found this post a few pages back:
I guess I'm not sure why.
