AVS › AVS Forum › Display Devices › Display Calibration › AVS HD 709 - Blu-ray & MP4 Calibration
AVS HD 709 - Blu-ray & MP4 Calibration - Page 6
post #151 of 3625
I was seeing some banding in U-571
I seem to recall there was some controversy about this title when it was released in the d-Theater dVHS format.... many saw banding in the dock scenes around the lights... it may well be in the source.
post #152 of 3625
Originally Posted by sticks4legs View Post
I've just copied and pasted from the owners manual
http://panasonic.ca/PDP/OperatingIns...000-oi-eng.pdf
You can monitor if the brightness and
contrast level of the input signal is in the
recommended range by displaying it in the
waveform monitor. See "WAVEFORM
MONITOR" on page 32.
1. Project a commercial adjusting signal.
2. Press the WAVEFORM button to display the
waveform monitor.
3. Press ENTER button to select the required
adjusting mode.
4. Press F G I H to adjust the displaying
position of the waveform monitor.
5. Adjust the waveform in each menu.
post #153 of 3625
Thanks for the quick response.
I also managed to find an old post from Kelvin1965S
dummies guide to the waveform monitor
http://www.avsforum.com/avs-vb/showt...veform+monitor
Post 19
post #154 of 3625
I would think the "single line scan" option could be used. As far as I can tell the feature gives a graphical representation of signal levels. I'm thinking if you go to the uniformity section you'll get a horizontal line across the monitor. I'm thinking if you use the windows it will show black (0%) at the outsides and the % window in the middle, so that if you went to the 100% window you could have both black and white on the monitor for setting brightness and contrast. If you use it for the colors, then you would probably want to use the 100% colors section. We do not have vertical gray bars like is shown in the manual (the middle of Misc Patterns chapter 1 might be similar), but by the best I can tell from their pictures I think the waveform monitor just relates signal levels. To me it looks like an amplitude monitor of some sort. By the "Any signal level below the recommended range will be forced to 0%" it appears anything below 0% will be clipped like can be seen on the black-clipping pattern from the disk (0% is 16 on the black-clipping pattern).
post #155 of 3625
Yeah, I need to try a couple of other movies to see if I get banding at this higher contrast. It is probably the movie. The thing is I see some banding even at the beginning during the Universal title.
Thanks for the suggestions.
post #156 of 3625
the blue ray version seems to think it's an iso image for a CD, but i see that it's supposed to be a DVD, but nero won't recognize the iso as one for a dvd. seems like there's a compatibility issue? i'm using nero 6.6. any ideas what i'm doing wrong?
post #157 of 3625
it happened to me as well, download and use imageburn...that works.
post #158 of 3625
alluringreality will have to look into that one, but it sounds like a Nero issue. Did you try burning it to CD? It may work.... I don't know if AVCHD has to be on DVD or if it can also be on CD.
post #159 of 3625
On the Nero 8 trial I was using to burn to UDF 2.5 for testing, you have to select DVD even though it initially comes up as CD. My player can't even read CDs and AVCHD is intended for DVD as far as I know, so I think it makes sense to burn to DVD. I would agree with the reply to try something other than Nero 6.
post #160 of 3625
i did try to burn to CD but it didn't work.
i'll try something other than nero 6.
thanks, i'll try that. is that the same program as imgburn?
post #161 of 3625
Yes. ImgBurn is basically the king of burning programs in my opinion. It doesn't have a thousand bells and whistles like Nero, but it does what it does exceptionally well.
post #162 of 3625
@vdiesel
Yes. Imgburn.
post #163 of 3625
Would it be possible to add something like what is shown at http://forums.microsoft.com/MSDN/Sho...73543&SiteID=1 to your disc. I think it would be useful do be able to see what a player is reporting as capabilities. I am going to be downloading your disc today and testing on new Samsung Duo player. I look forward to having it in my bag of tricks along with GetGray. Thanks.
post #164 of 3625
It looks like the link is broken. I get an error from the MSDN forums when I try to follow it. Can you double check it?
post #165 of 3625
The site is really slow sometimes, the link works but will time out. Try this link to msn cache of page. Sorry to make it difficult.
post #166 of 3625
I read the thread. I can't really understand what they are doing from that thread alone.
Do you know how they generated that output?
If anybody knows it will be Ron (dr1934). He may read this and give input. If you are really interested in it, you might want to start a new thread here or ask in the MSDN forums how it is done.
EDIT: Are they using HDi?
EDIT2: Nevermind, alluringreality figured it out.
post #167 of 3625
The first one worked for me, yet I'm not sure how someone would run that http://209.85.165.104/search?q=cache...lnk&cd=1&gl=us I find it interesting that a HD player can run it, but I really don't get the practical application. There's not much there that's there which is different between players or doesn't show up on a spec sheet. Beyond that, I would have to get permission to use it. Feel free to explian how to use it and the application, but aside from the "Player.capabilities.video.sub" nothing much caught my attention as interesting in the results.
post #168 of 3625
Honestly the reason I am interested is to test what a player truly supports with a given firmware vs. what was promised on a spec sheet. It might not have an ongoing use. I was just thinking it would be another data point for testing and verifying a player. I am not sure if there is a way to do the same on Blu-Ray using BD-J to interogate the player. Also as to permission I think this is a feature set built into the HDi JScript engine not some additional code.
I have just gotten a Samsung Duo player that claims support for TrueHD, however Batman Begins using something similar to this claims it doesn't. It would be nice to be able to verify.
Your disc may not be the best place for it though. Thanks for looking at it.
post #169 of 3625
I downloaded the HD-DVD version to try on the new Samsung BD-UP5000. The menu loads up fine but then I can't seem to navigate well.
1. I can move cursor to the right to down arrow, I can then hit the arrow to move the list. Once the list moves I can do nothing but move the list back up.
2. I can move to the second selection on the list but no farther down.
3. I can select either the top or second option and see the expanded rows but then I can't seem to do anything farther.
I can't seem to get the disc to actually play at all. I am sure this is a incomplete HDi in the player but I wanted to let you know. If I am doing something wrong let me know and I will try another way.
I just downloaded the AVC version and will try it and report back. One side question is in theory both discs should have the same ouptut correct on this player?
post #170 of 3625
Yes, they should both give the same output (we have verified that they are both the same on disc). Let us know what you find.
post #171 of 3625
Well I had less success with the AVCHD disc. The Duo just says disc can't be read and spits it back out. I burned both discs using same media and ImgBurn. Any ideas?
post #172 of 3625
It had to happen sooner or later, so 2000+ downloads for the first incompatability report isn't bad. I don't have too many ideas, except maybe listing the player as incompatible
Using your player model and AVCHD in a search basically returns nothing, so I'll guess the player doesn't support that format. BDMV in the player thread also didn't return much either except a mention of incompability on dvd+r, so I'm not necessarily inclined to upload that Blu-ray format. BDAV is the only other format, and that doesn't work with menus. In short in regards to Blu-ray on DVD, someone would have to inform me what the player can do because I didn't see any reports of it being able to play anything.
The HD DVD also sounds like a player issue of some sort. The only thing I can think to suggest is to try maybe a -r if you're using +r DVD. I suppose it's possible that either Ulead or Samsung might eventually get things to work if one of the two is the cause of the HD DVD issue.
post #173 of 3625
Using DVD Decryptor both formats read perfectly with a +disk on the LG BH100 dual player.
Go figure ??
post #174 of 3625
I doubt it is a -R vs. +R issue since the HD-DVD reads fine. I will try to get some -R just in case and test it though. I totally forgot that AVCHD isn't required spec for Blu-Ray so that is likely the issue. If I make any progress with HD-DVD I will post. I would be curious to see if anyone has success with BH200 since internally the two players are very similar.
post #175 of 3625
You may want to try a different brand of media as well. Sometimes players are very picky...
post #176 of 3625
I have an A3 but since I would be burning the iso to a standard DVD is there any difference between the two isos? Do I just use the HD-DVD version anyway?
post #177 of 3625
Both formats are intended to be burned to a single layer DVD+/-R. The HD DVD version plays in HD DVD players; the AVCHD version plays in Blu-ray players.
post #178 of 3625
These disks are HD formats. Even though they are put on DVD, the versions are entirely different. Just like how the disks will not play on DVD players, they will not work with incompatible players. The HD DVD will not even play on my XA2 if the Blu-ray version is included on the same disk.
post #179 of 3625
I just downloaded the AVCHD Beta 2 and tried to burn the ISO to DVD-R using NERO and Sonic but it looks the software wants a CD-R to burn the ISO not a DVD.
Is there something wrong I am doing?.
post #180 of 3625
You may have to select DVD manually within in Nero, don't know about Sonic. If you have a lot of trouble with it download ImgBurn and use it instead (it is free).
