AVS › AVS Forum › Display Devices › Display Calibration › AVS HD 709 - Blu-ray & MP4 Calibration
AVS HD 709 - Blu-ray & MP4 Calibration - Page 63
post #1861 of 3625
It's 75% similar to the commercial patterns.
post #1862 of 3625
Is there an easy way to calibrate the gamma?
What about saturation? (I don't have any blue filters)
post #1863 of 3625
i cannot get any of the .pdf pattern manuals to work. they all say they are an incorrect file type or corrupted. i have the newest version of adobe reader.
post #1864 of 3625
Does anyone have detailed instructions for unzipping the 7zip AVCHD file when using a new MacBook. This is my first Mac and I am not familiar with entering Unix commands. I have successfully made copies of my HD709 v1.2 disc, but would like to create a HD709 v 1.3 disc.
post #1865 of 3625
On linux I do:
7za x
filename
-Bill
post #1866 of 3625
Do you have p7zip? 7za is the command line tool.
post #1867 of 3625
I went to the link supplied on the main HD709 page and downloaded p7zip for the Mac. It contains a license agreement and the 7za command line version. Apparently you can enter command line instructions using Terminal. I believe the correct command line instruction is 7za e avchd-v1_3.7z but I have not tried it since I am unfamiliar with both the Mac, Unix, and Terminal on the Mac. What I really need is step-by-step instructions from someone with a Mac who has successfully created the disc.
post #1868 of 3625
Mount the p7zip dmg, copy 7za to your home directory, start a terminal, run ./7za e , burn the .iso file with DiskUtility.
post #1869 of 3625
Mount the p7zip dmg, copy 7za to your home directory, start a terminal, run ./7za -e , burn the .iso file with DiskUtility.
Thanks for your help. I did not know to add the ./ without your help. I burned the discs without any problems, and made 5 copies for several friends.
post #1870 of 3625
Instead of burning to a disc, can I put it on a usb stick plugged into my ps3 and run it from there?
post #1871 of 3625
if you want to use a usb stick, download the mp4 fileset. you can use this on a ps3
post #1872 of 3625
I have a Samsung LN55A950. Calibration was accomplished via the test disk run on a PS3. I also have a question about using a USB stick. For cable viewing the television is hooked up to a HD box Motorola DCT 6200. There is a USB plug-in on the HD cable box.
My question is: Would it be preferable to calibrate an HDMI input setting via the cable box for viewing with this device (provided that this is even possible) as opposed to calibrating one input with the PS3 and then copying the settings over to the other input used for cable viewing?
post #1873 of 3625
Just a tip, if you're new to Macs. Check out the Unarchiver. It opens just about anything with a double click, including 7zips. http://wakaba.c3.cx/s/apps/unarchiver.html
post #1874 of 3625
I just downloaded the HDMV 7-zip version from the first post here.
link goes to http://www.sendspace.com/file/8ialp6
But when I extract the 7zip file I dont see the ISO image. I see the BD's file structure instead.
Am I missing something?
post #1875 of 3625
The example steps for burning don't apply to the HDMV version. The HDMV is generally intended to be burned to BD-RE or BD-R with a Blu-ray burner. Just copy the files to disc and by default it should be formatted as intended. In Windows 7 or Vista SP3 you can copy files to Blu-ray media with Windows Explorer, or with ImgBurn the "Write files/folders to disc" option should work.
EDIT: If you want an image file, for example to work with PowerDVD, you can create an image with "create image from files/folders" in ImgBurn. Doing that or using the PATCHED image works with Virtual CloneDrive. For one of the other virtual drive programs it required the image to go over Dual-Layer DVD size before the program would identify the virtual disc as Blu-ray so that PowerDVD would read it.
post #1876 of 3625
Hi guys,
i cant download i also don't want to upgrade to the paid version of the sendspace, can anyone help e-mail to batibot8888@yahoo.com the mp4 version
post #1877 of 3625
what is the problem? Just click on the free version button on sendspace.
BTW, You gotta read the very first post here carefully first.
Originally Posted by ness88 View Post
Hi guys,
post #1878 of 3625
Thanks! I downloaded the patched version ISO...works fine!
This version works perfectly with PDVD. The older versions' menus never worked.
BTW what is the "patch" anyway?
post #1879 of 3625
AVCHD-Patcher was a program that can be used to make non-Java HDMV (Blu-ray) more similar to AVCHD. For example if you put basic Blu-ray (HDMV) files on DVD a US PS3 will not play it, but after the changes AVCHD-Patcher makes the files will play from DVD media. Having a second AVCHD style of disc is also necessary because a few different Blu-ray players either will or will not play HD video on DVD media depending if some extra empty folders are included.
post #1880 of 3625
Is there an SD DVD or mpeg version of the calibration files?
post #1881 of 3625
The GetGray disc is what I was using for DVD: http://www.calibrate.tv/. Some of its patterns made it onto AVS HD 709.
It's downloadable, but not free. The manual is available if you want to check that first.
-Bill
post #1882 of 3625
Great tip. I consider Unarchiver to be an essential Mac utility. I've been using it for years and it's still one of the best freeware programs around. Just to note, the current version of Unarchiver (2.2) includes XAD libraries that work beautifully with .7z files but some earlier versions (1.x) do not work well with 7-zip. There should be no problem as long as you are using Unarchiver 2.2 or later.
To be crystal clear for Mac beginners, once you extract the *.7z file to an *.iso file on your desktop, drag that *.iso file onto Disk Utility's icon (the disk with stethoscope icon in the Mac dock). Disk Utility's icon will bounce a couple of times while the program launches. Select the *.iso file below the gray separator bar in Disk Utility's left pane, insert a blank DVD, wait a few moments for the blank DVD to be recognized, then hit the black-and-yellow burn button. After Disk Utility completes the burn, it will typically spit out your newly burned disk (unless you clicked the "Mount on Desktop" option.) Trying to play this disk in your Mac's DVD player is pointless; it's designed for Blu-ray players.
Once you've confirmed you have a working AVSHC 709 disk in your Blu-ray player, you can safely trash the *.iso file. Keep the .7z file around if you want to make further copies in the future.
I hope that helps AVS Mac users. It really could not be simpler.
post #1883 of 3625
Just to add further confirmation that AVCHD v1_3.7 works perfectly on my JVC XV-BP1 Blu-ray deck running the current 2009-11-13 firmware. I didn't test it with the player's original firmware.
post #1884 of 3625
I can confirm that the PATCHED version, burned to a DVD-R, will play on a Denon DVD-1800BDCI.
Jeff
post #1885 of 3625
Can the HDMV files be used straight from media on a new Windows 7 laptop with HDMI port?
I could burn it to DVD, but I wonder if it would work straight from the hard disk in the machine?
(edit) The reason I ask is that I don't have a bluray player yet.
post #1886 of 3625
how does this compare to DVE on Blu ray?
post #1887 of 3625
Check the downloadable manual for details, but this disc has no tutorial material or audio tests. It's just patterns.
I have DVE but almost never use it, preferring this along with the Spears & Munsil disc.
-Bill
post #1888 of 3625
Adding to what wmcclain said, AVSHC 709 has no audio calibration, no support for 480i/p or 720p in some of the tests, no tutorial, etc. I'm not knocking AVSHC 709 -- it's great at what it does, and you can't argue with the price -- but this is no substitute for one of the commercial calibration discs if you're just starting out and need some hand holding. DVE could certainly use more hand holding itself. I'll probably pick up a copy of Spears and Munsil soon.
post #1889 of 3625
Spears & Munsil High-Definition Benchmark Blu-ray Disc Edition for $25 with SuperSaver shipping at Amazon -- got mine ordered. I don't see any more discs there with the free shipping, but check back later. Amazon can behave strangely sometimes with searches not revealing items that are there or only showing "affiliated vendors."
Back on topic, each disc has its own advantages. At 1/20th the cost of a professional calibrator visit why not own all three?
post #1890 of 3625
Hi Experts,
I try to calibrate my Popcorn Hour C-200 to correct some strange color decoding issues. The problem is that the C-200 use BT601 internally to decode un-flagged HD content (for example MKV's) but for flagged content it use the correct matrix of BT709.
Now I downloaded the non-flagged (1.2b) and the flagged (1.3b) version. I try to see the difference on my C-200 and also on the PS3.
Unfortunately I cant measure any difference between this two versions.
A test with this file:
http://www.cypheros.de/files/Testbil...ting_120sec.ts
It shows me that the colors a flashing if the BT709 flag is set or not but I cant see this with the AVCHD test disk.
Maybe I make some errors!? Can somebody help me?
The reason why I try to correct this are this two screenshots (form Highlander) where you can see that wrong color decoding is used:
Popcorn Hour C-200 or WDTV live
Panasonic BD35
Here are the details:
http://wdtvforum.com/main/index.php?...26980#msg26980
Cheers
Shepardos
