Originally Posted by Shepardos
A test with this file:
http://www.cypheros.de/files/Testbil...ting_120sec.ts
It shows me that the colors a flashing if the BT709 flag is set or not
So far I haven't been able to find any of my equipment reacting differently depending on flags. When I play the test clip the colors do not change, regardless of the text on-screen. If your player changes colors, then odds are it probably reacts differently depending on the video.
I cant see this with the AVCHD test disk.
Really the patterns here regarding flags are more centered around taking measurements from the screen. With a player that reacts differently depending on video flags, the behavior would be easier to notice by eye with the linked test clip. If you measured the screen, the patterns here might correspond with the linked test clip. From the WDTV link it seems that you're not measuring the screen, so in that case the differences with the AVS HD 709 patterns would probably be difficult to differentiate.
Based on prior discussions in this thread, different commercial Blu-rays may be either flagged or unflagged. On a quick glance it appears makeMKV retains the original video without any transcoding. If a player reacts differently depending on the flags, then all I can really suggest is transcoding the video to set the flags. I'm not familiar with different ways to necessarily do that. With x264 we used the following settings:
--colorprim bt709 --transfer bt709 --colormatrix bt709
