Originally Posted by alluringreality
Seeing pink would be what I called color shift. At the 21 setting if you see pink then you need to turn down contrast, because you do not want 230-235 showing pink. Turning down contrast will cause any color shift toward pink to happen at higher video levels, and you want to try to keep any shift toward pink above white (235). Using the contrast setting of 13 would probably be a generally safe setting where 230-235 will not have much color shift. If you want to go higher than 13, to have brighter whites, just try to limit any color shift near white. The Grayscale Ramp pattern from the Misc Patterns can also be used to look at any shift toward pink near white.
Thanks. Why am I also seeing all the bars at the -1,1 and 7 settings? This is why I don't know where to set contrast(-1, 1, 7 or 13).
