Probably explains a lot. With the DVE SD DVD. I would set the Gamma, on the plasma display for a reading of around 2.35. However, I managed a ruler flat gamma from 0ire to 100ire when the brightness and contrast were set with the black level test. However, with the AVS disc I find I can only get ruler flat between 10ire-90ire. Not a big issue, I hear you say. The only way I can get a ruler flat gamma is to clip the blacks to around 21-22 AVS and increase the contrast, which also is then slightly clipped.
This may be a characteristic of the Blu-ray player itself, rather than the disc?
