Originally Posted by
superleo
Here are the links to the full Photoshop PSDs. You need either Photoshop or Elements to open and/or edit.
For those of us who use Adobe Illustrator to print labels onto DVD/Blu-ray media, I've reworked the supplied materials into an AI file (version 10 and later compatible).
The text is now type (not vectored) and the Blu-ray/Dolby Digital logos are vectored, so they are nice and sharp when printed.
The 1080 and AVSHD-709 artwork is from the cover PSD file, as they were larger, meaning they are scaled down for the media, resulting in a crisper image.
The zip file containing the directory of the pieces is available from my
server. It is only 2,810,430 bytes.
The layout is for the Epson R1800, which uses A4 paper as the artboard. Placement of the layers will have to be changed for what your printer uses. Be sure and follow the simple instructions that are included on the artwork, otherwise you will not be happy with what is printed (ink where you don't want it
Thanks to superleo for the initial creation of the files.
I would like to know where the "Full HD 1080" logo came from, as I'd like to get as high a resolution version as possible. I like high resolution for some reason
Enjoy.
