Originally Posted by
buzzard767
I have a Panasonic DMP-BDT350 and have the same sticking chapter issue. All you have to do is hit the return key and then reselect the menu. Then it works fine. This happens on several but not all menus.
I did not think to try the return key on the remote, but my DMP-BD85K appears to respond like buzzard767.
It seems that the first visit to a sub-menu, for example Calman\\Fields, That when you select an item such as 3 step Grayscale, that the chapters stick until you enter the return key which brings you back up one step to the sub-menu. Then as long as you stay within that sub-menu chapters will change fine even when changing to another pattern set such as 11 step grayscale. Now if you go back to the main menu and re-enter a sub-menu, including the one you had just been in the process repeats. The chapters stick until you try to enter a pattern set and the back out of it to the sub-menu level and then all sets within that sub-menu behave until you go to the main menu again.
I hope this helps a bit...
Michael
