Thanks. Hmmm...I guess the HCFR windows are smaller, and are probably 100% levels, whereas I am using 75% on AVSHD709. However, I have used 100% level on AVSHD709 and there is very little difference between the 2. So, maybe it is due to the smaller windows?
I've used the APL 75% patterns on AVSHD709 and once again the difference, compared to the single window patterns, is very small.
The only pattern on AVSHD709, that brings the colour control down to -6, is the SMPTE colour bar pattern.
I gather I'll make all adjustments via the APL colour levels.
thanks
