It took forever to get to this point, but once I did it failed. What have I done wrong? The below is the event log:
I 23:07:48 Operation Started!
I 23:07:48 Source File: C:\\Users\\Tom\\AVS 709 Calibration\\AVCHD-2d.iso
I 23:07:48 Source File Sectors: 2,291,232 (MODE1/2048)
I 23:07:48 Source File Size: 4,692,443,136 bytes
I 23:07:48 Source File Volume Identifier: AVCHD-2d
I 23:07:48 Source File Volume Set Identifier: 3D7EAAC80022F238
I 23:07:48 Source File Application Identifier: ImgBurn v2.5.2.0
I 23:07:48 Source File Implementation Identifier: ImgBurn
I 23:07:48 Source File File System(s): UDF (2.50)
I 23:07:48 Destination Device: [0:0:0] HL-DT-ST DVD+-RW GSA-T21N A102 (D
(ATA)
I 23:07:48 Destination Media Type: DVD+RW (Disc ID: INFODISC-A10-01) (Speeds: 2.4x, 4x)
I 23:07:48 Destination Media Sectors: 2,295,104
I 23:07:48 Write Mode: DVD
I 23:07:48 Write Type: DAO
I 23:07:48 Write Speed: MAX
I 23:07:48 Link Size: Auto
I 23:07:48 Lock Volume: Yes
I 23:07:48 Test Mode: No
I 23:07:48 OPC: No
I 23:07:48 BURN-Proof: Enabled
I 23:07:51 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
I 23:07:51 Book Type Setting: N/A
I 23:07:51 Filling Buffer... (40 MB)
I 23:07:53 Writing LeadIn...
I 23:07:59 Writing Session 1 of 1... (1 Track, LBA: 0 - 2291231)
I 23:07:59 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2291231)
I 23:22:31 Synchronising Cache...
I 23:22:32 Closing Session...
I 23:22:33 Image MD5: 654920d1f3f1182423ecfbb75ff52263
I 23:22:33 Exporting Graph Data...
I 23:22:33 Graph Data File: C:\\Users\\Tom\\AppData\\Roaming\\ImgBurn\\Graph Data Files\\HL-DT-ST_DVD+-RW_GSA-T21N_A102_MONDAY-APRIL-11-2011_11-07_PM_INFODISC-A10-01_MAX.ibg
I 23:22:33 Export Successfully Completed!
I 23:22:33 Operation Successfully Completed! - Duration: 00:14:44
I 23:22:33 Average Write Rate: 5,261 KB/s (3.8x) - Maximum Write Rate: 5,645 KB/s (4.1x)
I 23:22:33 Cycling Tray before Verify...
W 01:53:43 Waiting for device to become ready...
I 01:53:47 Device Ready!
I 01:53:51 Operation Started!
I 01:53:51 Source Device: [0:0:0] HL-DT-ST DVD+-RW GSA-T21N A102 (D
(ATA)
I 01:53:51 Source Media Type: DVD+RW (Book Type: DVD+RW) (Disc ID: INFODISC-A10-01) (Speeds: 2.4x, 4x)
I 01:53:51 Image File: C:\\Users\\Tom\\AVS 709 Calibration\\AVCHD-2d.iso
I 01:53:51 Image File Sectors: 2,291,232 (MODE1/2048)
I 01:53:51 Image File Size: 4,692,443,136 bytes
I 01:53:51 Image File Volume Identifier: AVCHD-2d
I 01:53:51 Image File Volume Set Identifier: 3D7EAAC80022F238
I 01:53:51 Image File Application Identifier: ImgBurn v2.5.2.0
I 01:53:51 Image File Implementation Identifier: ImgBurn
I 01:53:51 Image File File System(s): UDF (2.50)
I 01:53:51 Read Speed (Data/Audio): MAX / MAX
I 01:53:51 Verifying Session 1 of 1... (1 Track, LBA: 0 - 2291231)
I 01:53:51 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 2291231)
W 01:54:36 Failed to Read Sector 76688 - Reason: Unknown (CRC or ECC Error) (ASC: 0x10, ASCQ: 0x90)
W 01:54:36 Sector 76688 maps to File: \\BDMV\\STREAM\\00006.m2ts
E 01:59:00 Failed to Read Sector 76688 - Reason: Unknown (CRC or ECC Error) (ASC: 0x10, ASCQ: 0x90)
E 01:59:00 Sector 76688 maps to File: \\BDMV\\STREAM\\00006.m2ts
E 01:59:00 Failed to Verify Sectors!
I 01:59:00 Exporting Graph Data...
I 01:59:00 Graph Data File: C:\\Users\\Tom\\AppData\\Roaming\\ImgBurn\\Graph Data Files\\HL-DT-ST_DVD+-RW_GSA-T21N_A102_MONDAY-APRIL-11-2011_11-07_PM_INFODISC-A10-01_MAX.ibg
I 01:59:00 Export Successfully Completed!
E 01:59:00 Operation Failed! - Duration: 00:05:08
I 01:59:00 Average Verify Rate: 497 KB/s (0.4x) - Maximum Verify Rate: 5,115 KB/s (3.7x)
(ATA)I 23:07:48 Destination Media Type: DVD+RW (Disc ID: INFODISC-A10-01) (Speeds: 2.4x, 4x)
I 23:07:48 OPC: No
(ATA)I 01:53:51 Source Media Type: DVD+RW (Book Type: DVD+RW) (Disc ID: INFODISC-A10-01) (Speeds: 2.4x, 4x)
