Originally Posted by smitty
This calibration DVD really helped me fine tune the black levels on my JVC RS1. The settings I got from Avia were off compared to using the two black level patterns. In other words, when I watched movies after calibrating with Avia, I could see a loss of shadow detail. After I calibrated using the DVD, I checked the results on a number of scenes that I use as benchmarks. These are scenes that I have never been able to get quite right, but with the good black levels of the RS1 and the patterns on this disc, I was able to get them just right.
Thanks to the developers.
Glad to hear AVS HD worked well for you. We found that most commercial disks lead you to set brightness too low in some cases. Its not because the patterns are inaccurate, but they are more difficult to read/examine correctly because they aren't as "fine" as the ones we use. In most of the patterns where you have an above black and slightly below black bar, the two bars are normally 4-5 digital "shades" apart. It seems to cause most people to overshoot the correct brightness because they can't see the intermediate shades as they change.
Anyone confirm?
