Originally Posted by
dennisjyp
still use the Movie mode, or other mode (standard, sport, dynamic)? And the same for my bluray player?
Typically it's possible to use the same mode setting, such as movie, for various sources.
I know that I have to calibrate the TV with each different source, so if I use the Movie mode for all 3 sources, isn't I have to change the setting everytime I when I use different source?
It's a good idea to check each source, but personally my electronics allow me to run the same settings at the TV regardless which source I use. When you check each source you may find that they can output standard video levels and don't require separate settings, but on the other hand you may find some sources that don't match. For example the Xbox can output either standard video levels or computer levels, so depending how it is set it may or may not match a typical Blu-ray player output.
I don't know what to do with it. I read the pdf manual, and it said I need to change the setting in blue mode so the flash box color (white & blue) should blend in with bar color. But do you guy know where is the blue mode in the UN55D8000 TV. Is it the RBG setting or other setting?
The HD Nation video, I think it's marked HDTV Calibation on the HDMV or AVCHD versions, has a demonstration of blue mode on a Samsung display. I would suggest watching the video and checking your TV manual for a similar option.
