AVS › AVS Forum › Display Devices › Display Calibration › AVS HD 709 - Blu-ray & MP4 Calibration
AVS HD 709 - Blu-ray & MP4 Calibration - Page 12
post #331 of 3650
Originally Posted by hwjohn View Post
I'm thinking that this gives you the excuse to buy a Blu-ray burner and test it for us
Yes, but I've had an excuse to for that for a long time . Just haven't got the time as my excuse to get another time consumer is getting longer and longer and longer....
post #332 of 3650
Originally Posted by stash64 View Post
Since I was planning to purchase the upcoming Oppo with Reon processor and it would probably come in around $300, I thought what the heck on the XA2. At the very least, this will be my last and best standard def DVD player. And just maybe HD-DVD still has a shot if they buy out one or two studios just like Sony did with Warner.
I think the new Oppo 983 will use the ABT processor, not the REON.
post #333 of 3650
You are correct, but I guess I would put the ABT and Silicon Optix processors in the same league. At least I hope so.
post #334 of 3650
Originally Posted by GetGray View Post
My Samsung 1400 won't play it? Anyone confirm?
Sorry dude, its all good on my 1400
post #335 of 3650
Your's plays the AVCHD version? Would you look and see what firmware you are running?
post #336 of 3650
But then you'll lose your excuse for a new player!
post #337 of 3650
Today, my anti-virus scan detected a trojan horse backdoor hupigon in the file AVCHD Beta 2.exe .
I think the mods should pay a close attention to this.
post #338 of 3650
It would be close to impossible for a virus to have worked its way into the .exe.
What software are you using to scan? Can you provide a screenshot?
post #339 of 3650
sure, I'll post it in about a minute or so.
post #340 of 3650
added caution note to top post
post #341 of 3650
here
post #342 of 3650
another one if the first one has been too compressed
post #343 of 3650
has anybody else who downloaded the file tried an anti-virus scan?
post #344 of 3650
I'm useing NOD23 and got no warnning after downloading today.
post #345 of 3650
I downloaded the file a while ago...
post #346 of 3650
I just scanned both files with AVG Free and got no warning. In the screenshot you are showing, there are two files listed. Are you sure the virus is not in the shell32 file you are showing?
post #347 of 3650
To date, both disks combined have been downloaded over 7000 times. We have never had a report of a virus, and as I stated before it is very highly unlikely that there actually is one.
post #348 of 3650
I just scanned it with Avast! and it didn't report anything.
post #349 of 3650
Mark,
What do we need to do to get this removed? Can you download and scan it yourself? Others (including myself) are not seeing any virus reported.
post #350 of 3650
Can you please update your virus software to the latest revision and definitions and scan it again?
I did some searching and apparently there are some False positives with older versions of AVG and 7zip. I am using the newest version of AVG and nothing is detected.
post #351 of 3650
This appears to be due to the most recent update of AVG. After I updated using the update manager it is now showing this for that file and the mameUI32.exe download. Anything that I create with 7-zip using the sfx option and ultra compression gets reported as a virus by AVG. At this point, I'm not so sure this isn't an error due to AVG since it seems to be from the most recent update and other virus software isn't showing it. I'm not sure what's on the computer at work, but NOD32 usually is held in rather good regard.
post #352 of 3650
I just forced my AVG to update, and I get same virus detected now too. The update must be very recent because my AVG had not prompted me for it yet (it checks every day).
At any rate, this has to be a false positive.
post #353 of 3650
-absolutely not, the shell32 file wasn't a treat at all, it was the avchd file that was a treat.
-I think it would explain a lot of things. It must be a false positive.
As for my antivirus, it's indeed AVGfree with the latest update.
post #354 of 3650
Mine too ! AVG v7.5.516 269.19.14/1247 latest Dat today 01/28/08
However , AVG performed a "heal" on the file and it didn't show up on a second scan . It resides in the Virus Vault now .
Interesting . Probably just a code sequence in your exe that resembles the Hupigon3.AMVL Trojan .
Scott................
post #355 of 3650
It looks 7zip sfx is triggering it. I wouldnt "heal" it and then use the disc because we dont know how that will affect the patterns.
post #356 of 3650
I already had burned the DVD, so I deleted the file anyways... BTW, it's an awesome tool!
post #357 of 3650
The latest which i assume is 1.5. After hooking her up to the net the MSG was i'm up to date
You are useing DVD-R ?
post #358 of 3650
downloaded the AVCHD version and Norton Antivirus detected virus on the .exe file. So I scanned it again with Kapersky Anti Virus Online, same virus detected.
Now the question is:... how many computers have been infected with this virus
post #359 of 3650
5?
post #360 of 3650
I'm not thrilled another program shows the same, but at this time Goolge shows nothing really useful to report http://www.google.com/search?hl=en&q=hupigon3+amvl I tried another computer with 7-zip with ultra compression and sfx http://www.filesend.net/download.php...b1e18fce572e30 and AVG reports the same thing and McAfee small business reports nothing.
