Originally Posted by alluringreality
The latest version was completely reauthored. During the reauthor there was an error found in with the v1.3 AVCHD authoring software, which may explain a report of measurements not matching exactly on a Panasonic player using the v1.3 AVCHD. If you are trying to use the CalMAN automation you would have to use whatever they support, but generally the recommendation is to use the last version. More release notes are at:
http://www.avsforum.com/avs-vb/showthread.php?p=19413135#post19413135
So, the latest version is from Nov 2010, right?
