Originally Posted by
sotti
There isn't a goto answer for YCC v RGB, different displays process color differently, so it's highly dependent on the TV.
As to Limited levels (Video Range) v Full levels (PC Range), If you have a plasma and you really need more light, by all means use Full range. Otherwise video range is fine, the games are typically signed off on in the default configuration, which means using Video Levels (At least at the good studios) and it's the right choice for video content.
Sotti, I am sure you can help shed some light on the following:
Need some clarity or at least some general guidance, as I have not been able to figure out how to make sense of this:
Two separate inputs that allow different Rec.’s and discrete scan rate memories for each input. I decided I want to use a DVD player and a Blu-ray player (two separate).
DVD Player: calibrate output/display to Rec. 601, and 480i & 480p. RGB or YCbCr?
Blu-ray Player: calibrate output/display to Rec. 709, and 1080i/p 24, 30, 60, 720p (checking 1080i30)? RGB or YCbCr?
Does the RGB v YCbCr decision boil down to processing? As in, if a display handles RGB, then use it (as long as there is not going to be a source sending it YCbCr, at which point I would need to verify that it is handling it properly). If it indicates problems – via multibursts, etc., then try YCbCr?
So, if had a display device, either a projector or panel, that calibrated fine at the resolutions sent to it in RGB, then there would be no need to calibrate also to YCbCr? Meaning, a device may discretely store settings for YCbCr separately from RGB. I would guess most anything sophisticated enough to have discrete memories would handle the conversion correctly, so it really shouldn’t matter whether it is RGB or YCbCr, but RGB is preferable. Is this correct logic or what you have experienced?
Lastly, in an article I read related to setting up the the DVDO, indicated, “For our BD player, we want the full dynamic range of "Computer”.” I assume this is 0-255, but 16 black.” This keeps the processing at a minimum or no remapping? This makes some sense if there is a fixed signal source, but I am not sure exactly what the advantage is. Is it just generally smoother, because there is no remapping/conversion? I realize this can get really sticky, I’m trying my best to keep breaking it down until it makes complete sense –then I am sure I will still forget something, but at least I will have good notes to keep reviewing.
I have a number of situations coming up where I will be adding in a dedicated DVD, but, really other than the Rec, I am still not clear on whether the output target should be YCC or RGB. One will be deployed with a DVDO, the other is a direct connect to a newer 1080p panel. So, If I am trying to close loop calibrate a specific input on a display to Rec 601, then YCC or RGB, or it depends -what are some of those "it depends"? Thanks, T.
