Originally Posted by osburnfamily
Sure-- Don't feel bad you're not alone in this one. It's a very known & argued/discussed problem with recent updates to the XBOX. I won't go into the real details; but, the jist if it is that correctly switching between YCbCr & RGB is pretty much busted and there's no 100% way to make it work correctly.
But you can get close.
http://forums.xbox.com/xbox_forums/general_discussion/f/135/p/171713/1784906.aspx#1784906
The above xbox forum link has four pages of some pretty intense back and forth.
The jist of it is if you're a gamer, you'll need to set the XBOX 360 Color Space to RGB (not Auto or Source), and the Reference Levels to Expanded. On your TV, set the HDMI Black Level to NORMAL (Not Low). Turn of Dynamic Contrast on the TV, then calibrate with the MP4 disk--
Here's the catch. You'll need to calibrate from the Xbox MediaCenter Extender, NOT the build in MediaPlayer.
I have a Samsung UND8000 and have gone this way and it's the only way that gets me correct games and video playback (netflix, hbo go, amazon, windows media center).
I'm confused about this process. I want to calibrate for xbox 360 gaming on my ST50. Can't I just burn the mp4 AVS HD 709 files to a CD/DVD or copy them to a usb flash drive and then play the patterns on the 360 (using the following instructions: http://www.ehow.com/how_6868844_play-mp4-files-xbox-360.html) or do I still have to use Xbox MediaCenter Extender for a proper calibration?
One other thing, my router is currently not working so I am connecting directly to the modem. Do I need a router to get Xbox MediaCenter Extender onto the 360?
