Originally Posted by
Crabalocker
I can't get the USB to work and I can't burn it to blu ray using IMGBurn.....Can I just buy the friggin disc somewhere? This has been the most frustrating thing ever.
Just wasted $25 worth of BD-R ARGGHHHH
Did you ever think of the possibility that your computer is infected with Malware?
Strongly suggest using `ALL 3' of these to scan your computer from `Safe Mode.' (Note: `Safe Mode' with Networking, not Normal Mode!)
http://www.freedrweb.com/cureit/?lng=en
www.eset.com/online-scanner
www.microsoft.com/security/scanner
Instructions:
Please note: the New Malware that is infecting CPUs is what I call Stealth Viruses.
Infects the Boot Sector of the Hard Drive, or installs first before any programs startup. The only way to detect this Malware is to remove your Hard Drive, boot up firstly with 3.5 Floppy on another Malware Free CPU and check Sectors 1 through 63. (An old copy from way back when of nu.exe with the /m switch helps greatly in this matter.) All Sectors except #1 should contain only Zeroes. If not, put them to all Zeroes. Replace Sector 1 with a new MBR.
We're seeing lots of this! What happens - as soon as you boot up, you're already infected! This infection now masks any other infections on your Hard Drive/s. (If you have more than 1 hard drive, also check the other drives. These malwares are know to put backups on the other drives.) Your AntiVirus has also been corrupted to look like it's working, but not! So, AntiVirus downloads new updates, scans, but finds nothing! Once the Boot Sector is taken care of, now scan your Hard Drive with the above mentioned Online Virus Scanners. Of course, we're assuming here that the CPU you're using is infection free?p5browne
Calibration Soldier
Private message
Edited by p5browne - 2/21/13 at 7:12am
