Originally Posted by kjgarrison
Maybe Tom will see this and respond. I have been thinking about this as well. Yes, I agree, it IS fun.
My opinion of why he chose Red as the primary to use in setting Color is that it is in between the other two, thus making any blue or green error only "one off", whereas using either blue or green to set Color makes the opposite end of the spectrum (green or blue) errors "two off". Also, blue error is the most tolerable to our eyes. Red and green errors bother more.
So, if you don't have CMS, you are as close as you can get to having all 3 in the ballpark by using red (although I have wondered if there isn't actually a intermediate point someplace between red and green (closer to red, probably) that would make all the errors comparable. And even if you do have CMS, by having your errors only one off, you have to make less of an adjustment.
Where R, G, B luminance "falls" is up to the color decoder on your set (assuming you don't have a CMS.) For instance, if you set Red correctly on two different TVs, one could have high Green and the other Low Green. Setting Red (or any other color) exactly correct doesn't guarantee that you have minimized the error in the other two colors.
The best way to set the color decoder is to look at each color individually and iterate until you find the setting that has the least error in each color. There is some merit to allowing more error in certain colors than others based on our perception of those colors. The important thing is to check the error for each color instead of just one so that you know you are getting the lowest error possible for each color. You will most likely have to settle on a color setting that is a compromise in error between each color.
EDIT: Just wanted to clarify that this info pertains to TVs with only one "master" color decoder control, usually labeled "Color." This accounts for the vast majority of TVs. The goal is to set that control so that the luminance values for each primary have the lowest error possible.
