AVS › AVS Forum › Display Devices › Display Calibration › AVS HD 709 - Blu-ray & MP4 Calibration
AVS HD 709 - Blu-ray & MP4 Calibration - Page 23
post #661 of 3625
does anyone have the md5 sum for the ISOs? (I am burning the hd dvd one, so naturally this is the one I would be most interested in.) mine is
58ba695205c9e0d5053979c91a9ad2b2
for the HD DVD iso file. is this correct? (my first attempt produced a coaster, but this could have been due to other issues.)
/iaw
post #662 of 3625
/iaw
Allluringreality is probably the one who would have to give you that. All the rest of us download it from a server.
post #663 of 3625
I did download it from the server mentioned in the leading message of this thread, too. I downloaded the windows .exe form. I ran it on a notebook with windows. then I had a file that needed some unarchiver (rar?). I did that too. Then I had an iso file. I moved it over to my main linux machine. it was 3,521,341,824 bytes long. this is also the file for which I computed the checksum. I believe md5 is a pretty common standard to ascertain whether a file is correct and unmodified.
anyway, I then loaded it into linux's k3b dvd/cd application, but k3b did not recognize it as an .iso file. I burned it anyway, and promptly had a coaster.
let's hope alluringreality can tell me whether I have a mistake earlier in the chain, or at the burning stage.
regards,
/iaw
post #664 of 3625
If you use the exe on a windows machine then an unarchiver shouldn't be necessary. The exe should go to iso. If that doesn't happen then use the 7zip version. There are really only two steps: unarchive (either exe or 7z), then burn resulting iso. I could probably get the checksum if necessary (orignals are on a different computer), but the way I read what you said you unarchived the same file twice which doesn't seem right.
post #665 of 3625
ok, I downloaded the .7z file now, and ran it all through linux. so this was a completely different process from start to end. I am happy to report that both the md5sum and the file size that I reported for the HD DVD .iso file is correct.
so, my problem is in the burning stage. working on it next...
/iaw
post #666 of 3625
First of all, thank you guys this is great, and very much appreciate your work and contribution.
I downloaded the exe file and had some trouble burning the iso. First I tried using XPburningrom freeware and it did not recognized the file as an ISO file.
I used DVDDecrypter and everything is working to perfection.
post #667 of 3625
I have a question, is there a DVD available with all these test patterns on it that will play on a standard DVD player?
I've got a Toshiba upscale DVD player connected via HDMI in our bedroom TV and I'd like to take some readings and do a calibration on it using HCFR, I've got DVE that is not for BR or HDDVD but it doesn't have the 0 IRE thru 100 IRE patterns that HCFR uses, is there something out like this or is there some settings that I can change within HCFR to use only certain patterns when take greyscale measurements?
post #668 of 3625
Check out this thread. Basic Guide to Color Calibration using a CMS. Tom Huffman has a DVD similar to the HD version. Not all the same test patterns, but very useful. Here is the link. http://www.avsforum.com/avs-vb/showthread.php?t=852536
post #669 of 3625
In addition to Tom Huffman's dvd, there is also GetGray - which is $25 - but well worth it. It's thread should be fairly close to the top somewhere. Just do a search for GetGray - Tom may also have a link to it from his sticky thread.
cheers,
--tom
post #670 of 3625
thank you
post #671 of 3625
creatine64 -- The AVS HD 709 calibration disc is not designed to be used in non-HD players. It is set up for HD only (hence the Rec 709 color coding). As was recommended, use the GetGray caldisc for SD players (which use the Rec. 601 color encoding). The web page for it is www.calibrate.tv and the forum page is here: http://www.avsforum.com/avs-vb/showt...&&#post7178409.
post #672 of 3625
Thanks to everyone that has work hard to make this disc possible. I had no problems downloading it or burning it to a BlueRay disc.
I'm currently using some cheap color filters that came with an older version of Avia to adjust the color settings. What type of equipment are folks using to do their calibrations? I need to be able to perform a more complete calibration of my front projector and LCD flat panels, but I don't want to spend $3-$5k on high end equipment, if possible. I looked at the Spyder3 Elite but I don't think it will work with the front projector. Anyone have any experience with Spyders?
post #673 of 3625
I just use ColorHCFR with a Display LT that cost about $140. The DTP-94 generally also gets good comments in the price range of a Spyder3, and you would probably need Calman for software with that option. http://www.avsforum.com/avs-vb/showthread.php?t=958099 has some comparisons of those colorimeters and the Spyder2 against the i1pro spectroradiometer which goes for a few hundred more. The major item in the charts is the delta E, where lower numbers would mean that the less expensive colorimeter compared favorably with the i1pro.
post #674 of 3625
The DTP-94 works fine with ColorHCFR.
RayJr
post #675 of 3625
My mistake... the free colorHCFR software must support:
HCFR colorimeter (DIY)
i1pro
i1 display LT/2
Spyder2
DTP-94
post #676 of 3625
That's right and upcoming version add Spyder3 support (tests on-going).
--Patrice
post #677 of 3625
Thanks for this! Just got it burned, going to try this tonight on my PS3.
post #678 of 3625
Just a note for those using the PS3; With the latest firmware, if you uncheck 1080i as a video output option the PS3 no longer forces 1080p output. The PS3 will downres to 720p instead. This should really only be an issue for the resolution patterns, but you never know.
post #679 of 3625
I just want to thank Alluringreality for posting this and enabling so many people do a user-level calibration. Many people can't afford a full-blown ISF calibration and this helps get a little more out of the set than what comes out of the box. Luckily I must have a decent eye, as my initial user settings were very close to what the result was using your disk. I only had to adjust the brightness on my Sony A3000 down one and do some tweaks to the centering of the image (horizontal = -2 and vertical = +3). Thanks again. I'll be keeping this in my subscriptions for any updates
post #680 of 3625
Has anyone had success with this on a Samsung 1400 other than the guy who burned it using a Mac? I burned the ISO to a DVD-R but all the Sammy does is pop the tray open when I put the disc in (After trying to load it).
If I calibrate the color decoder using Getgray or some other SD disc, would this be an issue vs. using a true 709 HD disc?
Tx
post #681 of 3625
I had a 1400 for a short time and I got it to work without a problem. I don't have the 1400 anymore but it should work.
post #682 of 3625
My copy works with BDP1400 no problem. Do you have the lastest firmware?
post #683 of 3625
Ha, david, I was the one who bought your 1400! What did you use to burn the image?
post #684 of 3625
Ha, david, I was the o0ne who bought your 1400! What did you use to burn the image?
post #685 of 3625
I use Nero 8, then choose "burn image", then choose the ISO image of the disc, burn the DVD-R at 4x on Taiyo Yuden media. How do you like the BD player? I still have another 1400 (this one is problematic) and won't play a lot of java discs. It's currently at Samsung being looked at.
post #686 of 3625
Don't have Nero unfortunately. Tried with image burn which worked in the past but no luck. So far so good with the 1400, had to downgrade to 1.6, and upgrade back to 1.7 to get some discs to work for some reason.
post #687 of 3625
Hmmmm weird!
post #688 of 3625
Thks to all the forum members involved with this calibration project.
post #689 of 3625
I downloaded the blu ray and hd dvd versions of this to calibrate my PS3 and my XBOX 360. Both are connected via HDMI to my Samsung 61A750. I was able to get the PS3 calibrated pretty good. When I went to do the XBOX 360 it looked like it does not output the same range as the PS3. When I am viewing the basic settings, I think it is the third pattern (the one that shows the white levels). I think this is the one where you set the contrast levels. On the PS3 I can see all of the blinking bars. On the XBOX 360, I can barely see one or two on the left hand side. I can not get any others to blink no matter how far I change brightness/contrast/dynamic contrast, etc, etc. Is this a limitation of the XBOX 360, am I doing something wrong, or could there be a problem with the HDMI port I have the 360 connected to?
Thanks for all of the help.
post #690 of 3625
I don't have the HD DVD drive, but the Xbox console settings allow for you to choose different output levels. The way I remember it there are three options. One is typical video levels, one is computer levels, and I'm not sure what the third does. My first guess would be that changing the Xbox setting could very well change how the patterns display.
