Originally Posted by
eddiscus
Tried the new revision on my pioneer BDP-05fd.
Navigation issues that exist are when you select for example grey scale patterns and it brings up the first pattern if I press the next button on the remote it goes to the next chapter not the next pattern. If I press the back button it jumps to the last pattern in the current chapter and will allow me to jump back to each previous pattern as well as skip forward to the next pattern. It just seems that the inital next command from the first pattern goes to the next chapter not the next pattern.
I'm confused and am not sure what you are saying. Generally I use the words patterns and chapters to mean the same thing, so that's probably part of why I don't get what you are saying. I also use sections and titles interchangeably. Anyway I will use the terms titles, chapters, and menus in what follows, because that's generally how many players read when you look at where you are at on the disc. I'll just describe how my Sony works with the disc in going to the "10% Fields" title on page 3 in the PDF.
1) Disk opens to main menu
2) Select "Measure Grayscale" for Grayscale Menu
3) Select "10% Fields" on Grayscale Menu
4) Player goes to Title 4, chapter 1
5) Next on remote goes to Title 4, chapter 2
6) Hitting back on the remote returns to Title 4, chapter 1
7) Hitting back on the remote again goes to Title 3, chapter 1
Generally the titles are intended to be selected from the menus, so if you are talking about how the player skips between titles then it very well could be different than before because we switched authoring programs. I know that even when we were just using Ulead for everything that my my players didn't work the same with the different versions for going between titles without going to the menu. I don't remember the specifics for how they switched differently between titles when chapter skipping or fast forwarding, but they all worked the same if a selection was chosen from the menu the player would go to the related title and first chapter.
