AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › Onkyo DV-HD805 - First End User Reports!
Onkyo DV-HD805 - First End User Reports! - Page 51
post #1501 of 1755
I have a European 805. Which European model equates to the North American XA2, please?
post #1502 of 1755
Joerod, your courage and unabashed nothing-to-it-but-to-do-it outlook is truly commendable. By taking that leap of faith, you've answered the pivotal question of the thread, apparently putting it to rest once and for all. Ballsy move, man...and thanks!
post #1503 of 1755
Chris, it will take Onkyo a long while to get caught up. I mean a long while...
Thanks BasicBlak! I will admit it was a loooong 12 minute update... I was sweating.
The player is still operating perfectly fine. I just tested August Rush and Elizabeth.... Hell, I may test all of my HD DVDs before long.
post #1504 of 1755
Anyone else do it yet?
post #1505 of 1755
I'll update mine once you test all your HD DVDs
post #1506 of 1755
I can now say I have put in about 75 of my discs to make sure they all load and play. When I get back this afternoon I plan to try another 50. After that I will declare victory!
post #1507 of 1755
I'll do it if someone will send me an official Toshiba 4.0 cd. (I'll pay you for it)
post #1508 of 1755
I have one but it is for an A35 and you need one for a XA2 I think...
post #1509 of 1755
I haven't decided whether to upgrade my XA2 or 805 yet, so don't want to give up the original disc, but I can make a copy of my official 4.0 CD if you want. PM me your address if interested.
post #1510 of 1755
I'll do my Integra if you will send me the backup firmware if mine bricks.
I'm still on the factory firmware.
post #1511 of 1755
Joe, I would also like a copy of the backup FW (I'm also still on 2.6). This is fantastic! Right now, I have no reason to upgrade to 4.0 anyway (I am limited to 1080i... no 1080p/24 yet), but when I do upgrade my display...
post #1512 of 1755
Anyone can get a firmware disc from Onkyo to have as a backup. I can't send my 3.? out. I think Onkyo was sending out 2.8 or 3.0 last I knew. My point is if you can get a disc from them to use as a backup then you should be good.
For the record, I used an official Toshiba 4.0 disc to update my unit. Not sure if there is a difference from the online one or not. I doubt it though...
post #1513 of 1755
I thought the only FW update from Onkyo was 2.8. They sent out a 3.0 update as well?
From what I understand from Toshiba's updates, you cannot regress FW version, unless you have a hacked copy. Am I to understand that if my Onkyo doesn't like the XA2 4.0 for whatever reason, i can go back to 2.8 (or whatever) by simply "downgrading" via the regular FW update process?
post #1514 of 1755
Now that I cannot verify. I wasn't planning to go back if I did not like it. I was only planning to fix a bricked player if needed. If it did brick then I was going to correct it with an onkyo firmware. I was told it would work if the worst happened by installing the toshiba 4.0 disc...
post #1515 of 1755
That's what I am confused about. If the player were to "brick", how would the FW update be applied in the first place? I am assuming that "brick" means that the player is completely unresponsive (can't eject the tray, etc)...
BTW, I cannot thank you enough, first for recommending this player (which i absolutely love), and then for giving us hope that the Tosh 4.0 update works for us as well. Here's hoping that the rest of your testing goes without a hitch!
post #1516 of 1755
I should clarify. I shouldn't say bricked. You are right, brick means completely off without powering on. I mean if it messes up where there would be no menu or gui and or disc recognition. If it went to that condition after loading the Toshiba 4.0 disc I was told if I re loaded an official onkyo disc it would resort back to normal. Good thing I did not have to worry about that. I am liking the performance of 4.0 so I have no plans to put it back to the normal Onkyo software (disc)... I am heading down now (just got in) to resume testing HD DVDs...
post #1517 of 1755
Thanks! I do have an official Onkyo 2.8 disc (that I never loaded), so I am covered on that front. I'm probably not going to update until I have need to do so (i.e. I get a 1080p/24 display, and need to get rid of the AVC jaggies), but I called Toshiba anyway and requested a XA2 4.0 upgrade disc ...
post #1518 of 1755
If you ever need to then you are all set.
post #1519 of 1755
Anyone want to sell your hd805 yet? Please drop me a line.
post #1520 of 1755
Joerod:
Have you tried any SD's? Notice any difference?
post #1521 of 1755
Haven't tried SD dvd. I usually use either my SP1000 or Denon 3800 for SD dvds. I will try one now. I just spent another hour testing about 25 more HD DVDs. So far still good...
post #1522 of 1755
Another thanks for being the guinea pig Joe.
So far no problems is good news.
post #1523 of 1755
I updated my Integra DHS 8.8 to 4.0 with no problems. So far playing very good. I downloaded version 4.0 from Toshiba and then copied to CD, works great. Try it you might like it!
post #1524 of 1755
I'm running firmware version 2.6 and haven't noticed any jaggies at 1080p/24. I thought the jaggies only popped up with firmware 2.8 and up? If I saw jaggies, I'd give firmware 4.0 a go, but right now I don't see a compelling reason to try the Toshiba 4.0 firmware. Am I way off base here?
post #1525 of 1755
Checked 180 discs as of now and still working fine. I also loaded 10 SD dvds... I say 4.0 is safe... This firmware is clean!
post #1526 of 1755
That's a good question... if the jaggies thing just popped up with FW 2.8, does 4.0 do anything other than fix the stuff that 2.8 broke in the first place?
post #1527 of 1755
Aw feck it, I'm going for it right now. I'll keep you posted (my player says "VERUP" on its display as I type this)...
post #1528 of 1755
Just select YES and you should be good...
post #1529 of 1755
I wish...I tried three different types of CDs and I keep getting a "2007c5c1" error right away.
post #1530 of 1755
Meh, I'm a dummy...I tried to burn the HD-A2 firmware! Here goes try #4...
  Back to Forum: HD DVD Players
