I have a Zenith DTT900 in my home office.
The antenna seen in the first photo is a Staples #1 Standard-Sized Indoor Antenna. (There are larger sized Staples models but the conductor is too large for the center hole in the Zenith's "in from antenna" fitting.) The Staples #1 Standard-Sized Indoor Antenna is priced at $2.99 for a box of 1,000 antennas. (Office Depot offers an indoor antenna of similar design priced at $3.99 for a box of 1,000 antennas.) To save space and maintain the low cost of packaging, the Staples #1 Standard-Sized Indoor Antenna comes folded and packed loose in a small paperboard box.
Here are the set-up instructions for the Staples #1 Standard-Sized Indoor Antenna:
1-Select and remove the Staples #1 Standard-Sized Indoor Antenna from its box.
2-Unfold and straighten the Staples #1 Standard-Sized Indoor Antenna, except for the last end-fold. That end-fold should be adjusted to a 90 degree angle, see the first photo for a correctly adjusted Staples #1 Standard-Sized Indoor Antenna.
3-Insert the shortest end of the Staples #1 Standard-Sized Indoor Antenna into the "in from antenna" fitting on the Zenith.
During operation keep the Staples #1 Standard-Sized Indoor Antenna from contacting other metal objects. Do not ground the Staples #1 Standard-Sized Indoor Antenna. Do not use the Staples #1 Standard-Sized Indoor Antenna (or an antenna of similar design) in circumstances where local or national codes require antenna grounding.
I am located line of sight less than five miles from the antenna farms in Portland Oregon. In my home-office, with windows facing the broadcast towers, the Staples #1 Standard-Sized Indoor Antenna provides nearly the same signal strength as with other Zenith CECBs connected to a RCA ANT111 and a Philips SDV2270/17 elsewhere in the house.
The Staples #1 Standard-Sized Indoor Antenna may also be used as a paperclip when left in the folded position, see the second photo.
). At this point I'm holding off on a preamp until after the cutover to see how things turn out and once the siding project on the house is done I'll shorten the RG-6 some.
