AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Master Burn-In/IR/Break In Thread Part II: All Posts Here Only
Master Burn-In/IR/Break In Thread Part II: All Posts Here Only - Page 41
post #1201 of 4271
1. No need to be overly cautious.
2. Set your tv setting to movie
3. If there is an option for orbiter, use maximum value.
4. Enjoy your tv
5. See item 1 above.
post #1202 of 4271
fatbottom,
Way to keep the discourse polite. I don't have any snarky graphics to post and I'm not going to call anyone names, but I think your doing so in response to some disagreement speaks clearly enough.
First we should clear up some nomenclature. It sounds to me like you are using the term "screenburn" to talk about what people here generally call image retention. Image retention means ghost images or patterns that fade after some fairly short amount of time. Screen burn or burn in is the term used around here to talk about permanent after images. I don't make up the terms but that's the way people use them here.
So you're now saying you can indeed get screenburn.
I do like the straw man argument. I never said burn in was impossible. Rather, I disagreed with your assertion that it was inevitable. Countless other people who game on their plasmas would agree with me.
jeff
post #1203 of 4271
^ I agree, we have to know just what fatbottom means when he talks about "screenburn" in order to properly respond. If he is talking about what we commonly refer to as "image retention" then of course the vast majority of us plasma owners would agree that this is a common occurrence. Most of us would also agree that this is not a significant concern since it is not visible during normal viewing and dissipates rather quickly. If fatbottom is referring to permanent burn-in then I believe most of us would agree that it is a pretty rare occurrence with normal usage.
post #1204 of 4271
The question I have is how apparent is IR when simply watching some TV or whatnot? 5-10 minutes to go away would stink if it were readily seen. Some have said you don't notice it on a non white screen, but then how do you notice it in the first place then?
post #1205 of 4271
I can't speak for everyone but I have never been able to see IR when watching any type of programming on my Panasonic 42px60u nor my Panasonic 50pz800u. To see IR I have to put on a black screen and stick my nose about 18" from the screen. I have only ever been able to see IR on a black screen, never on a white screen.
post #1206 of 4271
I was careful for the first 100 hours, keeping settings below 50%. When I hit 100 hours I started to play more games but tried to keep static displays in them to a minimum. Most times any IR I found was only noticeable on blank inputs and they would take anywhere from 5 to 60 minutes to disappear completely (usually used the break-in images on loop to do this since I don't have any cable tv at the moment).
I recently got Assassin's Creed on PS3 and after playing the game for two 1-2 hour sessions noticed that the health bar was visible not only on blank input but also over darker scenes in movies (like Batman Begins, Dark Knight etc) from my regular viewing distance.
I've been avoiding playing the game again until I clear this up, but after about 12 hours of trying different materials (running break-in images on SD card [which normally worked for removing HUD traces from playing GTAIV], scrolling white bar and just watching full screen content on blu-ray and DVD), the IR is still there.
Here's a pic to illustrate (top photo is unchanged, middle I altered levels in photoshop to make the outline easier to see and the bottom is a screen shot of the HUD from AC):http://i3.photobucket.com/albums/y97/Merc_2k/ACIR.jpg
(The image above makes the IR seem lighter than it actually appears to me on my set)
I'm afraid to play after this sort of thing happened.
Is this sort of thing cumulative? If I were to continue to play games with static elements in them, without completely erasing any IR in between sessions, would it continue to build until it becomes visible over bright content as well?
post #1207 of 4271
I'm pretty sure my cousin had the same model Plasma with the same problem. He played Madden 09 for a few hours and noticed that the score ticker could still be seen after not playing the game for days. Be ready for the Plasma lovers to call you a liar if the image retention doesn't go away and you post about burn-in. =(
post #1208 of 4271
Merc,
Please do keep us up to date on this. Reports like yours are just the opposite of what many of us have experienced with our own sets (I've done 5-6 hour sessions on consecutive days of various games on mine) without any problems, so whatever can be learned from your experience will benefit all of us. And no, all of us plasma owners won't jump in to call you a liar. But LCD fans like Homie are bound to spread your story far and wide with glee
If it makes you feel better, read this thread from a week or so ago:
http://www.avsforum.com/avs-vb/showthread.php?t=1098014
Owner in a panic over some video game IR that disappeared after a while.
Personally, I'd refrain from playing the same game if the HUD is remaining visible. Don't want to add more in case something is happening. Play other games, watch some full screen shows, run the break in images, etc. Perhaps take the precaution of pausing the game and switching to TV for a few minutes every hour while you hit the head/refill your beer?
jeff
post #1209 of 4271
What console games have no HUD at all or HUD's which disappear for example after you've been injured.
post #1210 of 4271
My experience is that almost every game's HUD is not on all the time. Either due to cut scenes, loading screens, reload after dying, in-game menus, etc. I've put quite a few hours in on Halo 3, Call of Duty 4, Gears of War 1 (and 2 presently), Mass Effect, Half Life 2, Portal, and Forza 2. All have HUDs of one kind or another and I quite honestly have never had any IR. And believe me, when I got my set I was looking for it
I'd be really interested to know of any games that do have images that would be on screen all the time, even during cut scenes, loading, etc.
jeff
post #1211 of 4271
Originally Posted by greenjp View Post
Merc,
Is this really atypical then? I'm still only about a month away from when I purchased the set and I could probably still get something done if this isn't proper behaviour for a plasma set.
Plasma is all new to me, so maybe I'm just unclear on properties of image retention. If anyone could answer either of the following questions, I'd appreciate it.
1) Does it only count as IR if it shows up over other images/programming? If it is only visible on a blank input or dark screen, does that still count?
2)(Assuming that blank input IR counts) How long should it take for an image to be retained on a blank screen or black background? If anything appears on the screen for a brief amount of time it can be seen on the blank input fairly soon. For instance, opening the menu on my Panasonic PX80U to change some picture settings. It only takes a few seconds to do, but the outline and some of the text can still be seen on a blank input immediately after it is closed. It goes away fairly quickly when other content is displayed (no more than a minute), but should it be appearing so soon?
post #1212 of 4271
I just got a Samsung PN50A400 and am having concerns about IR. I have 22 hours on it so far, and I've used tsanga's settings which put the brightness and contrast at about 50%. I set pixel shift to 4/4/1 from the beginning. Like Merc_2k I've noticed that I can see IR after just having the settings menu on the screen for a few seconds, but it goes away quickly, is this normal?
Also, I was getting IR from the Cable/Channel display in the upper left hand corner on the screen, which only comes up when changing channels, I could actually see it while watching the TV. Now, I've watched over 2 hours of Full Screen content and it is still slightly visible on the all white screen. I know it will go away but this seems overly sensitive. Seems like an oversight by Samsung to not make the menus translucent, can it be changed?
I really like the TV, but if this is abnormal IR behaiviour then I will return it. I don't know what to believe here. Thanks
post #1213 of 4271
This is normal.
It will lessen as you use your set.
Just use it like a tv and stop worrying.
Both my Sammy plasma's were broken in with gaming. One was left in torch mode for 4 months!
post #1214 of 4271
Is it true that you should burn in the first 100 hours in intervals of 10 hours per day for the first ten days to allow the phosphors to properly cure and resettle?
post #1215 of 4271
No, this is absolutely not necessary.
post #1216 of 4271
Ok I have just reached 180 hours with the burn in dvd on my 58 Samsung 650 , from what I can gather and from what I have read this is enough hours to now change my settings to optimal and begin to watch movies, regular programming and begin gaming. Am I forgetting something or should I let her rip?
post #1217 of 4271
After another 6-8 hours of fullscreen content (between Blu-ray, break in images and some Dead Space on PS3 [has no HUD]) I've managed to pretty much wipe out the IR from Assassin's Creed (there may be a little of the darker, horizontal bar left, but it's fairly difficult to spot now).
I decided to try a different game to see what would happen, so I gave Rock Band 2 a go for about half an hour. The IR of the fretboard and score meter were fairly distinct and, after about 4 hours of different content, the fretboard is still faintly visible like the Assassin's Creed IR was. I am currently running the break in images for a few more hours to try to remove it all.
I'm at about 175 hours on the set at this point, is this ever going to get better? I don't like the idea of having to spend these enormous amounts of time after gaming to clear away this stuff.
It seems like most people claim that they've never seen any IR on my model of TV, so what exactly am I doing wrong? I've got the pixel orbiter on force 1 (which, according to the manual, forces a pixel shift every minute). The settings I'm using are a little lower than most listed in the PX80 thread and I'm running it in Cinema, so it's not like I've got it in a torch mode or anything.
post #1218 of 4271
Is a set's sensitivity to IR affected by the Picture and Brightness settings?
post #1219 of 4271
That is correct
post #1220 of 4271
I don't think you're doing anything wrong. You will get IR on a plasma, those that say they've never had IR just haven't looked. I get IR all the time on both my Panasonic plasmas, more on my 42px60u than my 50pz800u. It isn't a problem though because I can only see it on a black screen with my face 18" from the screen. I have never been able to see it when viewing programming so I don't see it as a problem. I have the pixel orbiter on but never run the scrolling screen wipe feature, I just use my TV normally.
post #1221 of 4271
Does it take very long to get rid of the IR on your sets?
The part that concerns me the most about this is that a lot of posters (here and on other websites) say it takes quite a while to get any IR at all and, when they do get it, it is wiped away in a few short minutes of putting on a show or movie. It doesn't seem to take long at all for me to get IR and it takes hours rather than minutes to get rid of it.
post #1222 of 4271
Some people are just glossing over the IR problem. Right now I'm seeing IR on my Panasonic Viera TH-42PZ85U that is still there despite me watching 30 minutes of tv so no it won't wipe away in just a minute or two. The IR is only noticeable on a black screen.
post #1223 of 4271
Sometimes it takes only a few seconds and sometimes it takes a few hours for the IR to disipate. I don't obsess over it because it has never been a real problem. I've had my 42px60u for over two and a half years and IR appears very quickly, sometimes after only a few seconds of displaying a static image, but it has never been visible on anything but an all-black screen and only from a couple of feet or closer. I've only had my 50pz800u for a few months but IR is definitely not as apparent as on my older Panny but it does appear. It doesn't interfere with normal viewing so it isn't a problem for me.
post #1224 of 4271
IR happens. Just don't worry about it.
It lessens somewhat as the set gets older.
Lots of you younger folks won't remember what the old CRT's did when we first started gaming on them. IR was profound way back in the day as was burn in.
Just use your new set.
And the "break in" is a complete waste of your time. You will not lesen IR in the long run. But I won't poke fun at those who break in their tv's even though its not called for.
Just do what millions of others are doing.
Enjoy your set!
post #1225 of 4271
Hello and happy new year. I recently purchased a Pioneer Elite KURO 141 and Pioneer BP51 BluRay player. I also have an older Sony DVD player (non-bluray) in my home theater system. I am using the DVD breakin disc provided in this forum and I'm about half way through the breakin period for my screen.
Until now, I've been using my new bluray player to conduct the breakin. Is there any reason why I shouldn't be using the older Sony DVD player for this procedure and thereby reduce the number of hours on the new bluray unit??
post #1226 of 4271
It does not matter what you use to break in your plasma. The quality of the image does not matter so you can use your older DVD player. The only requirement is that what you use fills the entire screen and does not have any still images/logos. In my case, I zoomed a tv channel to remove the logo and used it to break in the plasma.
post #1227 of 4271
I'm running the DVD right now, and I had one query. Is it possible to set the brightness/contrast too low? I initially set it to about 30% and thought maybe its too low, so I have it about 40% now. Is there any advice on whats best? I have the PZ85. Thanks
post #1228 of 4271
I purchased the samsung Pn50a400 a month ago and have just cracked the 200 hr mark. I have been careful with it up until now, breaking the set in gradually as per schedule listed on this site, and I am happy with the results. In the beginning I would play xbox on it for no more than an hour at a time and only every three or four days. Mainly watched regular programing in full screen mode. After playing lego indiana jones for an hour or so there was a little ghosting in the top right hand corner that at first took a couple of hours to disappear. I would run the anti burnin functions on the tv, which are a great feature on the sammy, and watch regular programs. This would clear it up. I stopped gaming on the set for the last week or so after reading a few more posts about stubborn IR that some people were getting. Yesterday I decided that enough time had elapsed and played xbox for a couple of hours. I was really pleased that the ghosting took less than a half hour to completely disappear, and its getting less and less. I think that no matter what brand you buy, for every story of a samsung with stubborn IR, I have read another about a panasonic or a pioneer with the same problem, which leads me to believe that all sets are relatively equal in this respect. The technology has come a long way and will continue to improve. So for now I will enjoy my set, and looking to the future I am going to stick to plasma, because I think you cant beat them for picture quality, whether its for games, movies, tv, whatever! My two cents, for what its worth.
post #1229 of 4271
Hey joebloggs13,
Glad to hear this post It's funny because I was planning on posting because I have this same samsung PNA400 a Panasonic pz80u and a Pioneer 110FD they all have aproximately 500 to 800 hours or so now and the samsung about 300 hours. I have been trying to keep track of how they compare with IR. and they all do show it to some degree when new then settle and now mostly broken in now.
Just this past weekend done a test and tuned them all to ESPN news and ran all 3 with static Images for aprox 30 min with simular brightness not torch mode, as I.E. run aprox 58 contrast on the samsung And then go to a blank screen there after then to a White screen to a gray screen and Pioneer shows none the Panasonic very little takes 10 min to dissipate and the Sammy it does strongly retain that ESPN logo clearly Though I know it's not permeant and that took about an hour to clear with normal viewing with the wiper maybe 20 min to fully clear..
The samsung has been running a lot and has maybe 200 hours less and has greatly improved since and don't even worry about it much anymore it's just more susceptible to it than any TV i have owned and lacking black level, hence the super low cost i paid and it has a great picture so no Complaints here.
i do remember the Panasonic being sensitive to it first but quickly tamed away faster
will keep track of the Ir. and if it ever matches Ir resistance or the panasonic may take time but will post.
Den
post #1230 of 4271
I don't think all plasmas are equal in this regard; I've only owned one plasma, my current Kuro 6010FD, and no matter what I do it doesn't have IR, much less burn-in.
I can play Rock Band for hours, or leave the same frozen image up, and no IR. At first I was paranoid, but I'm now convinced it's immune, so I don't worry any more.
I did do the "burn in" DVD for the first 100 hours, which I now read was probably a waste of electricity, but oh well, no harm done.
