Originally Posted by
ajvandenb
Do you have evidence to support these statements?
No, but do you have evidence to state otherwise? The fact is that plasma uses phosphors that age rapidly within the first 500 hours. With break-in slides, which typically consist of red, green, blue and variations of white/black, you are guaranteeing that those phosphors are aged evenly over the first 100-200 hours.
If you watch regular content, the phosphors will age but, most likely, at a variable rate. It will eventually catch up to other phosphors and even out, but the time it takes to do so may be longer.
I would suggest a break-in if you want to get your set calibrated, either by an ISF professional or a DIY job using a colorimeter. Your picture does change within the first few hundred hours. Break-in assures that the service menu calibration that's done will last you a while.
