Originally Posted by
NickSP
Welcome to the paranoia of owning a plasma. LOL. Anyway, have you tried the built in white wash? I don't think BW snow helps much but I had a similar issue with Cartoon Network logo which did not seem to go away.
I ran the photo viewer with the colored slides for almost 14 hours and it went away.
I believe the trick is to watch with lower contrast and sharpness level. That has somehow helped me.
(You had 48 hours between your posts to all that?)
I noticed this over 48 hours ago and have been tackling the issue since. Yes, I've tried the Scroll Bar twice, plus playing the multi-colored DVD loop, also ran the Snowy Noise and watched 'Up' twice. It didn't really work but I think I should tone down the picture a bit like you've mentioned and just enjoy the TV, and (hopefully) let it disappear in time. My initial settings were pretty low -- using THX mode (57 Contrast/56 Brightness) and nothing has changed.
Buckeye911
Honestly, if you can only see it on a blank screen, what's the big deal? I just can't, for the life of me, understand why people freak out over a little IR when they can't even see it during normal viewing. Relax and enjoy your TV.
You're right, but I can spot it like a watermark from the movie 'UP' -- on the scene when they got to Paradise Falls where the skies had multiple-colored shades (much like the DVD loop); but only IF I look for it otherwise the chances of seeing it is slim to almost none. It's kind of like a 1% chance to even seeing it if one doesn't know, and yes I know I'm being anal about it! I guess from a psychological standpoint, when you know it's there you tend to look for it to make sure that it doesn't start to spread like cancer. Maybe I am freaking out a bit.
kris achar
Yes,even i used to think so,these channel guys are bent upon destroying the plasma tv's of their viewers.thereby creating fear amoung plasma tv buyers.
At least the HD channels could try to fade in fade out their logos from solid to transparent.Or make it spin gently once in every 15 to 20 secs.
But i have decided not to see much of cable tv using my plasma tv.instead use to watch BD movies in 1080p.
Channel logos are okay, I get them but as soon as I started watching something else they go away, but the one I have now is from my receiver. When I bring up the OSD menu, a big brand name logo is splashed dimly across the black screen, and another brightly lit smaller name logo on the upper middle-right screen; that was the one that got retained. I think I got it while I was setting up Audyssey for my 5.1 speakers which took over 30 minutes to complete. I bought the TV, Receiver and Speakers at the same time but shipped separately.
