Originally Posted by NickSP
Not that I want you to have IR ot BI (burn-in) but the real way to see IR or BI is to turn off ALL the lights in the room and then turn your TV on without any input being fed OR,
simply turn your TV off and although you turn your TV off, the phospors will still be active and show you all the BI or IR.
Now if these two tests above don't show you any of those then you are truly in plasma heaven (LOL).
Also, if you don't see any BI or IR while watching TV then you are also at the same place.
Done and done. I ALWAYS play video games in the dark and and though I didn't realize it was a valid test, I switched inputs over to a blank HDMI input (I use HDMI passthroughs) and it showed no IR at all.
Now that I know that was a valid test, I feel a million times better than I did yesterday. Wooohoo! Panasonic rocks!
lasma
