Originally Posted by ArchAngelGabriel
I figure I would update everyone... I now have about 30-40 more hours on the set since finding my history channel burn-in. Unfortunately, it is still there. I have not turned to the channel since... When I use the white-wash function I can see the history.com and even the logo sightly.
Not the end of the world, as It would be difficult to see under normal viewing circumstances... Just a bit upset though, because the set has been taken care of, I have been careful with it. I limited the time it was on the channel in the first place, but I guess that isn't enough.
My only hope at this point is the run the 'inverted' option and watch the channel for a long time. But that might make it worse. Does anyone have experience with that? I assume invert was created for that reason, but whether or not it will fix the uneven phosper wear (burn-in) is just a guess on my part. I'd hate to make it worse.
So here you go... My new LG 50PG20 has burn-in. On a side note, I looked at my friends plasma (Panny 42" 07' and and Sammy 50" 06') and both of them have signs of burn-in. My Dad's Dell W4200 05' (sammy for the most part) was used as a computer monitor for about 2 years and has only a very slight burn-in where the task bar was. All in all, the Dell faired the best in regards to burn-in, IMO.
I think people just don't know how to look for burn-in, or have never watched anything static on their screen. Or, I just happen to have seen it on the 4 Plasmas that I mentioned... A little bit bummed, honestly.
I don't think the inverse image thing was created to get rid of IR. In my opinion I would use that. I woudl stick with the white wash and just full screen HD content for as long as you can.
