Originally Posted by
daniel'son
Sony 32s3000 is 31.1 wide .. both this one and above are very good sets but check at store.
Also, are 720i .. but don't think you're Mom will mind this.
720p, i'm assuming thats what you meant.
That sony is the smallest i've seen as far as 32" goes. Your going to have a very hard time finding something under 31" wide, unless the bezel is extremely thin. I personally wouldn't pick a tv just because it's not as wide as others, but that's just my opinion.
Your options are either:
Wait until a 32" comes out that is under 31" wide
Go a little smaller, such as 26" or 27"
Use a slightly bigger cabinet
Unless that sony happens to fit in there.
EDIT: a Toshiba RF350 would probably fit perfectly if they made a 32" version, they have a very thin bezel. I doubt they are going to come out with one though, but who knows.
