AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › The new C3X1080 review.
post #1 of 877
So, whats' the word on the new Sim2 3 chip dlps? I could not go to CEDIA this year and I was hoping for a little info from those lucky enough to go. I have the C3X but I am willing to upgrade if the difference is significant. I was also hoping that Sim2 could fit it into the same body as the C3X which would make the upgrade a simple switch out. The ht 5000 doesn't fit well in my theater.
post #2 of 877
Any change the 1080p c3x using the darkchip 4? explain the >10k CR compare to the c3xe's 6500 CR.
post #3 of 877
Price??? Availability????
post #4 of 877
MSRP is $29995. coming Oct I was told.
post #5 of 877
Its a different machine ,not just a panel swap. DC4 is still a bit down the line.
post #6 of 877
do you know how long? I just place my order for one. would be kind of suck, if dc4 ones come out a month or two later.
post #7 of 877
The C3X includes the DC4....see below.
I was going to "e" my HT3000 but Im going to go for one of these I think.
post #8 of 877
I saw the C3X 1080p at Cedia today and it was very, very impressive. I think I am going to upgrade from my C3X 720p after seeing the demo. They demoed a HT3000e, C3Xe, and C3X 1080p. All looked great. Also attended a session on the new color management software which all these new units will have. It also looked very functional. Sim2 is kicking a$$ these days.
post #9 of 877
A couple of friends had a demo of the 1080 unit and said the same as yourself.
re color CMS, the single chip version is due in a couple of weeks.
post #10 of 877
FOR THOSE WHO SAW THE SIM2'S AT CEDIA Is there that much difference in color and and especially contrast between the C3XE and C3X 1080p. What if you are sitting beyond 1.5 screen widths back does the resolution look about the same? Thanks Greg
post #11 of 877
My C3X looks very good from 1.6 (2nd row) but my first row is about 1.3 and the pixels are very obvious. Is the new C3X 1080p pixel structure visible at 1.3. In general what is the difference between the 2 projectors in that regard?
post #12 of 877
I can assure you the C3X 1080 already has the DC4, the one we are demoing in our booth and on the TI booth has these new DMD's, so rest assured if you place an order now they will be included.
A big thank you to all that visited us today, your positive comments about our new products and the Live Colors calibration software is most welcome.
post #13 of 877
When will there be a press release with specifications provided on the new 1080p? Thanks Greg
post #14 of 877
Thanks for the info but .... Back to my question, Is the new C3X 1080p pixel structure visible at 1.3?
post #15 of 877
No 1080 machine will have a visible structure at 1.3 SW without binoculars . On my machines i need to go to within 0.5 SW
post #16 of 877
Wow, Thanks for letting me know! I am real excited now.
post #17 of 877
The press release mentions a one and two lamp version.
Was this the MSRP for the one or two lamp version?
Do you happpen to know the lumens spec for the two versions?
post #18 of 877
I'll definitely place that order until SIM2 upgrade the HT5000 with DC4.
BTW, how did TI's demo achieve a CR of 100K:1? Thru the use of DynamicBlack?
post #19 of 877
Please provide a link to the Sim2 press release.
ygoh
The 100000:1 needs dynamicblack since DC4 is about 10000:1 native.
post #20 of 877
Press release: http://www.dlp.com/tech/press_releas...s.aspx?id=1333
'.........At CEDIA (booth #620) DLP is showing multiple demonstrations, of the capabilities of the new chipset innovation. The DLP DarkChipā„¢ 4 Theater features a 3 chip, 1080p DLP projector featuring the new chipset producing trillions of colors combined with a native contrast ratio of 15,000:1. Additionally, there is a demonstration of a DLP HDTV with DarkChip 4 and LED illumination with a native contrast performance beyond 100,000 to 1.......'
post #21 of 877
Leds is no advantage in reaching a higher native contrast ratio. To me it is a lie. 100000:1 with DynamicBlack is for sure but not without it.
post #22 of 877
Do you a US based public company would lie in press release?
post #23 of 877
Samsung uses local dimming leds and gets 500000:1!
Its more true to say that the leds are 100000:1 than to imply that dlp has anything to do with it. It is the system that has a native contrast.
In say RS2 one pixel can be totally off and some other pixles fully on. Their ratio could in theory be 30000:1. In the rptv dlp I think the max in theory ratio between two pixels could be between 5000-10000:1 or so.
post #24 of 877
If you are confusing the HT5000 then the 2nd lamp is around $10k extra.
post #25 of 877
Like coldmachine said, I don't think there's a two lamp version for the 1080p c3x.
post #26 of 877
There isn't. (Tight enough fit already in that C3X box.) (Which is also the reason there is no horiz. lens shift, and limited vert. shift).
post #27 of 877
Question for Alan Roser. Does the new C3X use the same variable lamp intensity setting as the old one?
I experienced bulb flicker with a C3X I owned, and experienced it in a 3000e that I demoed. It appears to be an issue related to the variable lamp output adjustment, and the lamp ballast. Adjusting the output, can make the problem go away, at least temporarily.
Has anything been changed to adress the issue of bulb flicker in this new projector, and the 3000e?
post #28 of 877
Has the vertical lens shift been improved at all? I mount on a high rear shelf in the upright position, and have to use keystone correction due to the limited shift on Sim2 projectors.
post #29 of 877
Can anyone at CEDIA tell me if the screen at the demos for the Sim2 is an SMX screen by any chance? Ruben said they might be using one.
post #30 of 877
Being totally honest here..... the higher end machines are really meant for an on axis install. I would never have a $30k or $50k machine installed in anything othere than absolute true. Any off axis install will be a compromise.
How much do you need?
My last 3 models had between 0.25 and 0.5 screen height. Are you that far out?
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
