AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › The new C3X1080 review.
The new C3X1080 review. - Page 6
post #151 of 877
Originally Posted by Jason Turk View Post
I haven't had time to finish my C3X1080 review, but preliminary numbers for light output are about 1100-1300 @250watt, iris open. Note that is D65 numbers, I got quite a bit higher than that out of the box. Also note, it is a PITA to calibrate. There is an issue with the service menu that Sim2 is aware of and working at fixing.
Nice light output !
Art
post #152 of 877
I have to say that is hands down the ugliest thing I have ever seen. No wonder you have to mount it into a closet.
post #153 of 877
Beauty is in the eye of the beholder...
post #154 of 877
Originally Posted by coldmachine View Post
" All your base are belong to us" is a very well known Internet phrase, and is purely humorous in nature. Google it.
Never mind post removed.
post #155 of 877
Mine too. No problem.
post #156 of 877
True...that is probably why I think I am so attractive.
post #157 of 877
Thank goodness... I may just have to order a 12' wide screen since I'm stuck using the T-1 lens... Whew! So nice not to have to deal with dim projectors anymore... this is really exciting!! I can't wait to experience MTF MAXIMUS!! That Ruby Image was getting so flat and boring... That being said I can't wait to give it to my dad since the Ruby will still be so very nice for him... He should really like it!!
post #158 of 877
Mine too.
So you two decided against the late night tryst after all? Thank God, and in the future please keep such talk off line.
post #159 of 877
QQQ. Did you get your free bottle of Eco Spray yet? Have you tried it yet?
post #160 of 877
what light output can it do at say 8000K and a good contrast on off (say 5000:1) ?
remember guys, dlp is king of ansi contrast, reaching sometimes up to 800:1
and that is very very important for daylight scenes
and with a scope format screen, I don't miss the 20000:1 of some machines
post #161 of 877
In college a few buddies and I went to the beach on spring break and that was the comment made about one of the girls I was with.
Art
post #162 of 877
word...
post #163 of 877
hehe!!
post #164 of 877
LOL That was good Art.
post #165 of 877
But the other two girls Art was with, WOW! You see he wanted a threesome but naively thought that was three women and one guy. Instead of two women and one guy. He also has trouble figuring out port sizes. Something about the cosine of the angle of the dangle . . . .
post #166 of 877
Received my C3X today and while I await official installation assistance I thought I'd start playing with it. I haven't had much luck.
Can someone check my logic? Max throw (T2 lens) is 2.6. The 16x9 portion of my 2.35 screen is 100" (just over 8' wide). Max throw should be 260" right? I have it at that distance and the image is 120" wide.
I'm also getting keystone effect on one side. What would cause this?
It also seems to me I won't be able to use my anamorphic lens as the image out of the C3X lens is too large for my Prismasonic (maybe because the C3X lens is recessed...?)
post #167 of 877
Ian:
Throw distances where modified (increased) I don't remember the exact numbers but that Is probably why you have a 120" image, I don't know about keystone effect
post #168 of 877
Ian, you are posting half your problems here and half in an HT380 thread, people will miss stuff and not be able to help fully. Not to mention the trail of irrelevant and uninformed posts that are already starting on the other thread. Wont be long till theyre on this one too muddying the waters.
post #169 of 877
I wish someone could tell me if the T2 lens could actually do 1.7.... I think Sim says 1.75 so that people with 1.65 don;t try to squeeze into a T2 lens... I am at 1.7 max, but am now afraid to gamble that the T2 could do 1.7...
post #170 of 877
Trapezoid on the sides indicate the lens is not parallel, left/right to the screen The top and bottom of say a white screen should be the same lengths and ditto for the sides. Move the orientation of theproector to obtain a perfet rectangle.
Are you saying you have the lens at 260" throw? A max width of 120 would be a throw ratio of 2.166.
post #171 of 877
You are asking for trouble at the end stop.
post #172 of 877
Well, what were the odds my ideal mounting spot would be 1.7 Odds I could squeeze into a T2 = ?? 95%?
By end stop, do you mean mounting at 1.66 for the T1?
post #173 of 877
Ian, it could also be that the zoom is too wide. If your image was more in line, say 8' wide instead of 10', you might actually be able to fit it into your prismasonic. 8(
Hopefully when your installer gets there he can solve some of these problems for you. Since you dont have it ceiling mounted yet, at least you can put it on a table and move it up some to enjoy the image while you figure it out.
post #174 of 877
The recess and case is the issue. Beam width will be too great. ISCOs are wide enough.
post #175 of 877
By the way, I would be using an ISCO 3 as well, so not sure how that affects this issue... Could always zoom if I have the T1
post #176 of 877
By end stop i mean the extreme ends of the zoom. AVOID like the plague
post #177 of 877
ISCO is no problem
post #178 of 877
You are 20' back from an 8' wide (16:9 measurements) screen and you cant get it into a prismasonic lens?
How far recessed is that PJ lens? More than 3 inches in?
post #179 of 877
So you are saying that if I am at 1.7, I should try to see if I can get to 1.71 and maybe take a chance on the T2 lens working? Or are you saying I should mount it at 1.5 and use the T1 lens...
post #180 of 877
Im saying, as i already have , more than once..AVOID THE ENDS
If you need to change your size or throw, thats up to you.
pm me again.
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
