Ok, I tried some searching and browsing of the stickies, but I would really like input based on my specific situation. If the admins feel this is a redudant topic and would like to direct me to some specific discussions I can read through, that would be fine.
So, I am just now stepping into the HDTV world. I know plenty about mid range home theater and stuff, but need some advice on what I should look for in this case.
The TV will be used for regular programming [haven't decided on satellite or cable yet... I am currently splitting my neighbors cable line for free... no box, but not much quality either], as well as gaming and movies. I plan on purchasing an HD-DVD player at the same time as the TV. I have a PS2 and a Wii. I may get a PS3 down the road, but thats not at all a definate.
My girlfriend [lives with me] took one long look at an LCD display and said "no way, that pixelation sucks, especially for games". I agreed with her.
So, I have heard Plasma is king, but projection is also an excelent option.
so, my criteria is a display that will work well with my PS2, Wii, an HD-DVD player, and is acceptable for SD material [like videos and broadcasts].
I am looking for between 42" and 52" and can spend up to about $1200.
I would really like to hear experience with Plasma vs. DLP vs. LCD projection with gaming. I can definately see motion blur with LCD flat panels.
I don't have a very large living room wich is the main reason I don't want to go bigger than 52". 46" is really ideal, but this is a less common size. 42" and 50" are both definately acceptable.
thank you for all the help in advance.
