I just downloaded the .zip and have version 0.52 running under OS 10.5.1 on a MacBook and a MacBook Pro. So, the archive seems to be okay.
A MacBook Pro is about the last thing I'd expect to have trouble running it.
Time to ask the usual suspects....
1. Try making a new user account seeing if it runs under a generic account.
2. Temporarily disconnect external drives and volumes and see if that makes a difference.
3. Firewall? I doubt this is the problem since it is fine even even with the firewall set to only essential.
4. Failing the above fixing things, the next thing I'd do is let Onyx do its "automation" routines (also with maintenance scripts and clearing all caches)
Beyond that, I'm perplexed.
Oh.... Might be worth first downloading a fresh copy of the .zip and trying with a new copy.
