AVS › AVS Forum › Audio › Soundbars › Best budget subwoofer for yamaha sound bar?
post #1 of 2
I've been looking for a sub woofer to match up with my yamaha ysp-800 I bought at best buy for $170 (marked down from $800) while they had a clearance for them. As you can imagine, for 170 it sounds great. Everyone has said the sound quality doubles with dedicated sub.
So Im looking for subs around the same I paid for the sound bar. The Dayton SUB-100 10" for $100 seems to be the best bet from what i've researched. People have reported the sub that yamaha makes for there soundbars pairs really well, but Id imagine a more dedicated speaker manufacturer would make a better sub. Now whats important to remember is the system is a surround sound bar, so anything more than a 10 inch sub would probably be too overpowering. Not looking to spend more than $200. Will mostly be used for gaming and movies, but music is important too as I play music games like rock band or guitar hero.Thanks for any help or advice in advance.
post #2 of 2
There is no such thing as an overpowering subwoofer. They have a volume control knob for a reason. That said, you should also consider the Dayton SUB-120, too.
  Back to Forum: Soundbars
