In my old house, using multiple Buffalo wifi routers (using WDS) worked great. When we moved to our new (old) house, it never really worked very well.
I had frequent skips, lockups, and video/audio hiccups.
After messing with settings and antennas, I finally gave up.
I went to ebay, and picked up several Motorola NIM100 MoCA boxes.
These boxes transmit ethernet over your cable TV coax. It is able to go through multiple splitters, and the like. They auto configure.
You will need one NIM100 for each Replay, and unless your router does MoCA (i.e. if you have Verizon Fios) you will need one more to connect the coax to your router.
In my home, with a rat's nest of cable TV coax, I still get 70-80Mbs through the coax. <4ms ping time. I haven't noticed any network video artifacts since I changed to MoCA.
If you are diligent with your ebay monitoring, you can pick them up for $30-$50 a piece.
There is one guy who is selling brand new ones for $75 (+shipping).
I believe that Verizon is pulling these out of many of their older markets, so there seems to be an ample supply of them on ebay.
It is curious that such an easy, well performing product is not sold retail - but, ebay is the only spot to get them (unless you know a Verizon guy).
Can finally use my second MediaMVP in the bedroom and not deal with my wireless bridging problems...
