AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › HD-A30 and homemade movies
post #1 of 13
Im looking to pick up the HD-A30. Does anyone know if it will play the stack of DVD+R movie copies that I have?
post #2 of 13
Are they authored as HD DVDs? If so, I can confirm that yes they do work.
I'm not sure why standard definition would be any different if that's what you meant.
post #3 of 13
As long as they are authored as dvds or hd dvds, they should work.
post #4 of 13
They are copies of standard definition movies. The specs on the player says it supports DVD-R, but I'm not sure if that includes DVD+R discs. Besides playing HDDVD's, we also plan to use it as an upconverting DVD player for our std def movies, which were burnt onto DVD+R discs.
post #5 of 13
Even though +R disks are not spec'd for these players, people who tried have reported success. I tried a couple on my A3, and they all worked without any problem. I believe that the HD-DVD drives in all 3rd gen players are the same.
post #6 of 13
I can confirm that DVD+Rs play flawlessly on the A2, A3, and A35. I'll assume that the drive in the A30 is the same.
post #7 of 13
DVD+Rs were in fact invented by toshiba , Just like the optical connection that was also Invented by them which is "Toslink".
In fact more info can be found about dvd players, burning dvds and free apps at. :
www.videohelp.com
post #8 of 13
Thanks for all the responses!
post #9 of 13
Someone said that the reason DVD+R is not listed in the manual is because it is not a DVD forum approved format but DVD-R is (sort of like blu-Ray lol).
post #10 of 13
It depends how they were authored. Legal copies of non-copy protected things that I own play fine. However, DVD+R's recorded with my Magnanox MRV700 set-top DVD recorder won't play in my Toshiba A2 or A20. DVD+R DL's are an entirely different ball of wax.
post #11 of 13
Set top dvd recorders record in a different format than dvd roms.
post #12 of 13
please help i have a question, why A30 powers up and read the disc extrememely slow, is this normal? will a firmware update help with this problem or it is just how HD DVD works? how can a brand new out of the box unit need an update?
post #13 of 13
You should update the firmware. There have been slight upgrades to the boot times. It's still a little slow though.
  Back to Forum: HD DVD Players
