hello all.. i need some advice in deciding between a 40inch samsung 61 series or a 40inch sony s3000.. i will use the tv mainly for sd veiwing and hd mainly for sports and some xbox360 gaming. which has better pq and less problems. the samsung is only $100 more then the sony and i get 1080p with the samsung.. i compared them both at bb side by side and the sony seemed to have the better color but i thought i can adjust the samsung. also one more question which has a better processor? thanks any help would be appreciated
AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › help for deciding 40in samsung 61 or sony s3000
AVS Top Picks
post #2 of 4
12/8/07 at 2:31pm
post #3 of 4
12/8/07 at 2:46pm
post #4 of 4
12/8/07 at 3:09pm
