Originally Posted by kasabe23
Also, How best to explain the connection on 120V 60Hz on the back of the Bluray device as it maximum fps is 60. How do I relate the the 60Hz elctrical ac cycle rate to the max output of fps? I tried to say that IF their were 120Hz source equipment out their, then the bluray player would say 120V 120Hz on the back of it?
you don't.
no. it wouldn't say "120hz" on the back of it...
think about it for a second... IF (big if) someone does come out with 120 hz (frame rate) source equipment, it's unlikely that the entire power grid will switch over to 120hz (a/c cycle rate) in order to accomodate them...
