Originally Posted by
onecrazyfoo4u
I stumbled upon this thread after finding out ED went out of business. Now my current dillema is I have a Nine.1 Amp (paired to a 13aV.2 sub) that has recently gone bad. Is there any way to get an ED amplifier repaired? I don't mind paying for the repair; I think it's outside of the warranty period anyways. I've had the setup for 4 years now and it's been flawless until this week. Here's some details of the problems:
These are the symptoms with the ignition key 'Off':
- Amplifier power wire gets 12.9v when you unhook it from the
amplifier. When it's hooked up to the amplifier it gets 5v.
- The 4 30amp fuses on the amp all get 5v too, with the power wire connected.
- The speaker wire outputs all get 5v too, with the power wire connected.
- The remote wire gets 0v.
These are the symptoms with the ignition key turned 'On':
amplifier. When it's hooked up to the amplifier it gets 2.8v.
- The speaker outputs all get 8v with the power wire connected.
- The remote turn on gets 12.9v when unhooked from the amplifier.
When it’s hooked up to the amplifier it gets 2.2v.
The amplifier has 4 30amp fuses on the side. When I pull all 4 30amp
fuses out the attached power wire gets 12.9v again. And each fuse
receptacle and each speaker output all get 12.9v with the power wire
disconnected. When I add just one of the fuses back in it goes back
to 5v. So it seems like the fuses getting plugged in trips the
voltage back down low. But the fuses all look brand new.
I also checked voltage before and after the main, inline 125amp fuse;
that gives 12.9v before and after the fuse. So the main fuse is good.
I'm at a loss of what to check next! Thanks guys.
