I bought my A5-350 back in 2007 (the old downward facing 350's). The LT-550 amp failed in early 2008, they replaced it back then, and it has worked ever since.
Does anyone know if that replaced amp probably already has the modifications that will hopefully prevent it from going out again? I'm not sure if all the LT-550 amps were the same model, but mine has the Keiga part number KGD-5250 (serial number scratched out - which seems to be common).
thanks...
thanks...
If I manually move the sub, it's quite stiff, but it's smooth and I don't hear anything scratching.
