AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › What kind of connections should I wire up inside the drywall?
post #1 of 3
My TV and the rest of the A/V gear are separated by a considerable distance. So that I don't have ugly wire running all over the place, I'm going to install the wire inside the walls. My TV supports a myriad of inputs (two HDMI, two components, two composites, VGA, and S/Video). My question is should I bother supporting all of these connection types to future-proof my install, or should I just do HDMI and maybe VGA? I don't plan on buying any video equipment that doesn't support a digital output if I can help it. Also, if I ever replace the TV in the future I'll be sure to make sure it has digital inputs. So it would seem like bothering with the component, composite, and S/Video cabling would be both a waste of time and a whole lot of money.
Opinions?
post #2 of 3
Opinions?
I would run HDMI providing thats what your gear is running on now or what you expect it to be running on. Fry's sells some nice wall plate/hdmi deals.
If you want to future proof the situation run conduit from the location to that of your other equipment and leave a pull string inside the conduit....that way if something changes you can simply pull the new wires.
post #3 of 3
run some 2" conduit then you can easily run whatever cables you want and change them out when something new comes along or a cable goes bad. future proof and cheap
