Originally Posted by
rcserg
I do have a box, it is in another room hooked to another TV as well. One box can feed two TVs. The coaxial is run from to the box to my TV.
Well then, you probably have two options:
- Run an audio cable from the box to the TV.
- Try either of the solutions above and see if they work (I don't see why not).
There should be instructions with your TV on how to turn off the TV speaker, or it may be automatic if it detects an audio output cable connected. Connect the audio cable to the appropriate audio input for satellite on the h/k and select that input when watching TV. It shouldn't be difficult to do.
